Advise for a first time Welder
   / Advise for a first time Welder #1
jerry shannon
jackson michigan
oliver 1855 Diesel, Bobcat 863F skidsteer, john deere 855
A possible first time welder here. I am tired of sending out my welding to be done and am thinking of getting into a unit and start learning how to do basic welding. I was thinking of a Hobart Handler 190 mig welder as my all around unit. Opinions of this brand and model please.
Also is in fact a Mig welder my best overall first choice for a welder. I was told it would do everything I would need for most all farm and home applications.
Look forward to your ideas and thank you. By the way, I do most all of my own repairs and maintenance and consider myself to very handy.
   / Advise for a first time Welder #4
You can't weld in even mildly windy conditions with a Mig.
Repairs on old weathered stuff isn't easy either. Not that I know what I am doing, but I ripped a safety chain off of a trailer last week and tried to weld it back on with my Mig. It was just put on with some snot as a steel boat builder I once knew called it. I managed but it wasn't a pretty job.
Migs are best for putting together shiny new stuff! So if you are planning on building stuff, Mig is the way to go. If you are doing a lot of farm repairs, a DC welder is probably better. Lots of rods to chose from.
   / Advise for a first time Welder #5
Remember when Mig welding, you want to run as hot as you can handle it. Cold lap is the number one killer of Mig welds. In other words, buy the biggest Mig machine you can afford! ;)
   / Advise for a first time Welder #6
If you are starting out, I would suggest buying an old tombstone on the cheap and learn how to stick weld...
Mig is great but stick has some advantages...
Typically higher welding capacity for the same dollar...
Dirty windy conditions lend itself to stick also...
Harder to operate but not that difficult...
You may have a local community college to help in the training...
That is a good option for lots of folks...
   / Advise for a first time Welder #7
I'm new myself but don't forget with a mig welder you can use Flux Core wire and you don't need gas...it melts metal better and is not affected by wind...You pros correct me if I'm wrong ..but it has worked for me...I just have to knock and brush of the slag and pull the puddle instead of push...I.m happy with mine.
   / Advise for a first time Welder #8
Strictly non-pro here. If I have anything that actually 'counts', I have a pro handle it for me.
That being said, The hardest thing it seems for most beginners I've run into is they don't see or understand or how to look for and watch and control the pool of molten metal that's being pushed or maybe rather blended together. That being with torches, mig or stick.
If only that were just beginners that'd be okay I guess but I run into the same thing from people that have doing it forever.
For beginners I always suggest starting with a set of gas torches. Learn how to control that welding process and it's limitations. Then arc welding becomes much easier in terms of whats happening as well as gauging the worth of the finished product.
Shrug, or maybe that's just because that's the way I started. lol
I do not know how big of material I will ultimately be working on but to start light stuff mostly. I have some Oliver flat top fenders that I cut old steel out of and will be wanting to weld new still back in. Ground off all the material around the parts to weld and they are all nice and shiney but I hear what you are saying about the repairs. I think I will be doing 80% new stuff and 20% old repair. MIg still the safest bet you think?
Good advise. I am going to take some night courses at the local Community College to get some instruction and then just go for it. Right now still trying to decide how much to spend on a unit and what unit to get that will be a good starter and best overall multi purpose or multi surface welder.
2017 GMC Sierra 1500 Elevation Crew Cab Pickup Truck (A51692)
2017 GMC Sierra...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
