Advice on Tractor (second)
   / Advice on Tractor (second) #1
jcmseven
Veteran Member
western NC
JD 2320; 4520
Fellow Posters:
I am asking the group for some advice regarding the purchase of a smaller tractor for my property. Here is my situation: I have about five acres of heavily wooded, hilly land; my parents have about two acres at their primary residence and another two at a mountain cabin they just completed. My parents are both in their 70's and although reasonably healthy, they do rely on me some to help at their place. I just bought (four months ago) a JD 3720 which I really like and would like to keep as my primary machine. Currently I only have a FEL and BB for this tractor, and may add other attachments in the future. I have a Gator UTV which I might sell, as I do not use it much except for driving around. I use my 3720 mainly for loader work and grading around my property and some for the neighborhood association as well. It is clear a mid frame compact such as the 3720 is good for many of the tasks I need and I feel in many instances I could not go smaller. I have several areas on my property where my 3000 series simply will not fit and could use a reasonably priced smaller machine to use in those places but I am not sure which way to go, as it would be a second machine. I would want something with which I could do some light grading and perhaps loader work, some snow removal in tight places in winter, some mowing for my parents and that would be stable on some of the hills that perhaps a larger machine would not handle as well. Some of these areas are quite tight and the ground is soft and at times, not even close to flat. I also would like for any machine I get to be easy to transport on a utility trailer. I have looked at smaller JD's, Steiners, and the PowerTrac ad's. I am partial to green, but do not have to have a JD. Since it would be a second machine for more specialized use, I would like to keep the cost down, and used would not be out of the question. Cost is variable so a number may not be applicable. I am interested to hear thoughts about which direction I should look for the most versatile small machine I can consider and why. Thanks in advance for all the help.
John M
   / Advice on Tractor (second) #2
I would suggest looking at used 4xx series Deeres. Light enough for towing and mowing, but heavy for its size, good hydraulics, and many implements available for it too. They also come in 4 wheel steer - great option for mowing, snow plowing in tight spaces, and stability (but greatly reduces ground clearance).
Also, you might consider a Simplicity Legacy or BX series Kubota. Or if you want bigger, the TYM T233 or Kioti CK20 are also very nice machines. New Holland and MF offer similar sized tractors as well. My choice of all of these (if money was no object) would be the TYM.
   / Advice on Tractor (second) #3
I was in the same position as you 2 years ago. I have a wide range of tractors, but needed something small and manageable for my 10 acre home while I'm getting ready to sell it. I would look at a JD 585 if any dealers have them, or a new 7XX series, I have a 585 w/HDAP tires. You can get a huge list of attachments for it including loader, front, mid, or rear blade, snowblower, tiller, spreaders, and on and on... The reason I say the garden tractor instead of say the 2210 is becouse they are made in the good old U.S.A. where the sub compacts are Yanmar. The garden tractors are a little more $$$, and the 3pt is limited cat1 (if you think you even need to add 3pt and PTO), but they work good. I prefered the gas motor over diesel for the type of work the tractor was going to do. I have the front blade with the angling kit. I can't tilt it like a rear blade, but I love the hydraulic angling and the fact I can lift the front end off the ground and dig with it. Nice for patching ruts and small area's without disturbing the whole area. It also works good for plowing snow too. If you opt to snowblow vs. plowing, 4wd and a front mount snowthrower/blower is the only way to go. I live in MN, I don't use chains or weights with my 585 w/HDAP tires, and haven't been stuck yet. Part of the driveway at the farm is quite steep. Unless you have large lawns to mow, the 54" deck would work fine vs. going to the 62". Sometimes I wish I still had a 54" deck, but I get my 3 acres of lawn mowed so much faster with the 62", it makes up for the lack of manuverability. I mow my ditches on my 10 acre home, I had a 425 before the 585 and locking the 585 in 4wd sure makes the tractor more stable sidehilling than the 425 was. If you order, or get a choce in used, get the HDAP tires over the bar or turf. I have had a few garden tractors over the years and those HDAP tires are the best I have ever seen/used. JMHO, good luck.
   / Advice on Tractor (second) #4
I'd get a Power Trac 425 if I were you. I strongly considered one myself before I struck a deal on the JD 2320 earlier this week. However, I will admit the Power trac has several advantages over my new machine and most compact tractors. They are extremly manuverable. They are great at loader work having quite a bit more lift for a comparable size compact tractor. No balast needed either as the engine is in the rear. With it's articulated frame, it can get into tighter spots than most anything else. With their low profile Power Tracsdesign, they are very good on slopes as well. Steiners and Ventrac's are nice as well. They are better mowers from what I have read than Power Tracs, but not nearly as good as a loader and not as versatile as the Power Tracs.
Power Tracs are not that expensive to begin with either. A PT 425 starts at 10k. And you just need to add the quick attach implement of your choice. So a PT with a loader bucket is $10450. You can add a grapple bucket for $1700. A post Hole Digger with down pressure can be had for $1100. A mini hoe can be added for arounf $1400. For the same price as the Deere I just bought i could have had a Power Trac fully loaded. It's just not a Deere though, so you already have that covered with your 3720.
I still would like to get one myself someday and will keep my eye out for a good low hour used PT 425.
   / Advice on Tractor (second) #5
Another consideration might be a Ventrac, made here in Ohio. They are primarily aimed at the commercial/industrial/governmental market, but are a very tough multipurpose machine.
   / Advice on Tractor (second) #6
I'd look at an SCUT in the high teens to low 20's hp.. 4wd, power steering.
Anything from a kubota BX series.. tot he NH TZ/ small TC series.. even the SCUT that MF has, as well as the economy brand chinese tractors.. they have some super cheap scut at 20 hp with 4wd... etc.
soundguy
jcmseven said:
Fellow Poster
John M
I appreciate the comments to this point. I think all the points and suggestions made to this point have been excellent. As I mentioned, I really do not have a firm budget, but I just do not wish to spend too much on a second machine. Our hospital has a Steiner which it just bought, and I assume the Ventrac is similar, and it seems nice. Unfortunately a new one of those machines is close to 20K with the attachments I need and that is not TOO much less expensive than the JD I have. The PowerTrac's have intrigued me, and I like them. I am just a little concerned about the lack of dealer network, but if I were to go that way, would a 422 or 425 be better for my use? Finally, I think a SCUT would be the trick and I am familiar with the JD 2305, but what are some going prices on a Kubota BX or NH tractor, for comparison? In fact such a small machine would probably do all I need to do regularly, but once one goes to a bigger machine, it is hard to go back to something small exclusively, so this is one reason I would keep the larger tractor as well. Decisions, decisions. Thanks again and any thoughts or further info is always appreciated.
John M
   / Advice on Tractor (second) #8
Go look at a JD 790. Old technology and therefore very affordable. No HST or modern electronics and it has moderate hydraulics. Easy to haul on a 16' trailer. Plus, it is only about 60" wide and will essentially go almost anyplace your gator will. You can probably use some of the Cat 1 attachments you already own.
   / Advice on Tractor (second) #9
If interested in a Power Trac, I would spend some time down at the Power Trac forum. Look up some of the long time members post such as Moss Roads and you will be amazed at what these machines can do. Most members down their seem to like the PT 425 as it is not to big or small.
Also, I'm not sure where you live in Western NC, but the Power Tracs are made in Tazewell Va. (South West Virginia) kind of near Blacksburg. Might not be to far to go. You can save 5% by visiting the factory. Everything on the PT is hydraulic and from what I've read they are very simple to maintain.
Well enough of my selling, I'm sure you will pick something appropriate.
   / Advice on Tractor (second) #10
I can understand the need for two tractors. I just bought the large and decided to keep the small. There are just so many things the SCUT tractor will do and places it is easy to use. It is also a great mower. The added bonus is I get to keep a backhoe that, although small, does all I ever need a backhoe to do.
I am partial to Kubota and I'm pretty sure the BX would fit what you are looking for as would many of the tractors already mentioned.
Enjoy the adventure of shopping for the right tractor!
Terry
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A53472)
2017 Yale GLC050VX...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
