advice on sound attenuating material for fence
   / advice on sound attenuating material for fence #1
snodley55
southeast Ohio
Hoping to get a little advice from the folks here on TBN.
I'm planning on building a double-sided privacy fence, 12' tall, to reduce the noise of a neighbor's barking dog. My plan is to isolate the outer wooden materials on both sides from the 4X4 posts using a layer of foam that is normally used to seal sill plates where they meet a block or concrete foundation.
However, my real question is the best material to place in the 3 1/2 inch cavity between the two faces of the fence. I'm considering 3/4" or 1" extruded expanded polystyrene (such as the green Dow-board), or 3/4" foil-faced polyisocyanurate (such as the Tuff-R or R-Max), or possibly even two layers of the old asphalt covered 1/2" fiberboard sheathing. All these materials are available in 4X8 sheets
I'd appreciate any knowledge anyone has on the relative sound deadening effect of any of these three options.
Thanks in advance,
John
   / advice on sound attenuating material for fence #2
somex sty;e acoustic foam or any egg=crate foam will be good to break up the sound.. Unfortunately, many of the real good options won't survive the weather ( sonex and similar foams should ). I'd check the acoustic rating on the rmax, and then compair to the 2" bulk styrofoam sheeting.
There are 'spray' coating you can put on the fence outter side as well. In general sounds are absorbed best by thick / soft/ angular surfaces.
Unfortunately.. some sounds that are hi, like a dogs barking.. or a car horn.. make it thru soundproofing pretty good due to their frequency. They also reflect well and bounce alot off of hard angular surfaces.
IMHO.. I'd check with your local police and see if there wasn't a noise ordinance.. I'd bet you do have one. Around here, 'noise abatement' tickets can be issued by code enforcement. non payment, or subsequent violations are usually punishible by fine, then jail, and/or animal seizure.
While not a super easy case.. you may even be able to sure for injunctive relief.. etc
I'd get quotes on the materials and labor, and then pursue all the other options and build the fence as a last resort.
I'd also smoke over any deed restrictions that may/may not exist in your area. A call to the county attorney may also help you research applicable law on this matter, before you contact the police.. etc.
good luck.
Soundguy
   / advice on sound attenuating material for fence #3
Welcome to TBN John. What part of the country is this in? Might be cheaper to invest in a nice set of headphones and a stereo. Who moved next to who? City dog or country dog?
   / advice on sound attenuating material for fence #4
I doubt you'll have much luck with the fence. How cooperative is your neighbor? Is he willing to help or is he the don't give a ^&&% type?
If he is cooperative you might look into one of the anti-bark shock or spray collars. Even if you buy it that will be much less expensive than the fence.
I had a neighbor barking dog problem a few years back, I even tried an ultrasonic speaker by the fence that was supposed to irritate the dog when he barked and eventually train him to stop. Didn't work, he'd cock his head look at it quizically and keep barking. That dog is lucky I love dogs, otherwise he might have disappeared. Fortunately they moved.:D
To answer a few of the questions:
BTDT, I've lived here about fifteen years, neighbor with dog has been here two months. It's not in city limits, so no zoning in effect.
Skyco, I've talked to them four times. Each time I get the story that "he just barks when the UPS man drives in". Yeah, that and every time they drive in, I drive in, the mailman comes by, anytime anyone steps out of their house, anytime he hears another dog bark within two miles, anytime he feels like it, and usually two or three times during the night. So I guess you could categorize them as the "don't give a %$#@ type".
I tried the Super bark-free from First and Foremost, with no results. I also offered to buy a bark training collar, but no-go on that.
Consequently, fence seemed to be the last resort.
John
   / advice on sound attenuating material for fence #6
buy a leaf blower, chainsaw or similar loud machine and run it everytime the dog barks. Tell them you just run it when the fedex guy is here.
   / advice on sound attenuating material for fence #7
Sounds has a way of going over and around barriers. I think that if you build a 100%sound proof fence, or wall, all you will do is waste your money.
My house that I used to own in California backed up to a freeway. When they first built the freeway, the lined the sides of it, and the back of the homes with shrubs. Mostly Oleanders, but others as well. This cut down on some of the debri that the roads kicked up, but didn't do much for the sound. When the widened the freeway in the 90's, they build a sound wall that was 12 feet tall, out of blocks. It cost a millond dollars a mile to build, and really didn't accomplish much. My house still had plenty of road noise being right next to the freeway, but now homes that were farther away that didn't have the noise, also got it. The wall sort of acts like a ramp to send the sound further back then before.
Putting double pain windows on the house made a HUGE differnce.
My fear is that you will build this fence, put allot of money into it, and still have the noise. It might even be worse, as the sound might deflect off of the wall and carry further like it does at my old home.
The people living under the flight path of the SF International Airport sued the airport about all the noise the planes made. They won the lawsuite and the airport had to pay for soundproofing to a large number of homes. I know one of the people who live there, and they installed 4 pain windows in his house. I have no idea where you get 4 pain windows, or what they cost, but they are so good that you cannot hear jet aircraft flying over your house with them installed.
You would also save money on your energy bill if you soundproofed your house instead of your fence. It's another option that might have multiple benifits with a solid return on your money, versus taking a gamble that you can stop sound from going over your fence.
Good luck,
Eddie
   / advice on sound attenuating material for fence #8
I have a don't give a *&^( neighbor that used to have a dog that barked all the time. I tried talking to him and got the response "he only barks when someone is in the driveway or there is a problem." So every time the dogs barking would wake me up, 2:00am ,4:00am I'd call the neighbor (sometimes more then once). To say I hear the dog barking, is there a problem, do you need any help, etc. After a few months of an "over concerned" neighbor offering to "help" at 2:00am the dog was gone. Because I took the overly nice route we're still on speaking terms (when required).
   / advice on sound attenuating material for fence #9
I was just thinking about this thread.. and.. Gosh.. I'm glad i dont have #$%holes for neighbors. I have indoor dogs ( little yappie lap dogs ).. and outdoor dogs. the outdoor dogs literally only bark if somebody walks on my property... thus we virtually never hear from them. The yappie dogs are initially quiet, but get distracted easilly and will bark at butterflies.. etc. I make it a point to monitor the dogs when I let them out... as soon as I hear the first bark.. in they come.
If everyone just had some common courtesy like that.. there wouldn't bee much problem.
Soundguy
   / advice on sound attenuating material for fence #10
I really like this aproach. It makes your neighbor admit his dog is barking and doesn't let him ignore it. He can't do anthing about you calling, because your just being concerned. Man, that's a great way to fight back!!!!
Eddie
CASE IH 2555 4R COTTON PICKER (A51247)
CASE IH 2555 4R...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2019 JOHN DEERE XUV835M LOT IDENTIFIER 25 (A53084)
2019 JOHN DEERE...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2024 Greatbear Forklift Jib (A51573)
2024 Greatbear...
