Advice on recent quotes
   / Advice on recent quotes #1
WV birdman
Moncks Corner
None
Quoted 31,400 and 33,000 on RX6620 and 7320. Open station, power shuttle and 6' HD box blade. 5.74 rate and zero down (which I didn't ask for...plan to put down 20%). Rate seems high. Thoughts and opinions welcome, please.
   / Advice on recent quotes #2
I haven't priced those tractors so I don't know how good/bad those quotes are, but they are in the ballpark of what I would expect based on pricing of DK10 and NX models.
Financing is often lower cost through a local bank that knows the dealer vs. Kioti itself. You can of course also shop around any bank or credit union you want. The financing on tractors doesn't seem to be as cheap as on cars though. I would hope you could find something in the 4-5% range today, but that's just guessing.
   / Advice on recent quotes #3
As far as the 6' HD box blade, if it doesn't weigh 1000lb or at least close, it is not really HD. With either of those tractors, really need a 78"-84" unit IMO. Might want to get both rear remotes to start with. ;)
Good luck with your decisions, both are nice machines. :thumbsup:
Actually waiting on a response on whether or not any remotes are included. I'm with you on the box blade, I honestly assumed he would quote a 7 footer being that the tractors are as wide as they are but he didn't so I'll square that away. Might just see if I can hunt up a good used one and save some coin.
   / Advice on recent quotes #6
Drop the box blade (I doubt your dealer is going to have anything that's in the right ballpark as pertains to HD for these tractors) and instead get a couple more rear remotes.
I've got an 84", 1,200 lb box blade for my NX5510. Has hydraulic scarifiers, which I've found aren't required in order to really bite into the ground; when using, however, that's a second set of rear remotes (first being for the hydraulic top link, which is a must). I'm running a set of hoses up to the front of the loader for my grapple, that's three remotes in use!
   / Advice on recent quotes #7
If you put down 20% or more you should be under 3% interest with decent credit.
Toro Mower (A50324)
Toro Mower (A50324)
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
