Advice on project
   / Advice on project #1
jsduke
Bronze Member
West Central Pa.
PT-425 (Former Kubota L3130 HST)
Hello all.
My neighbor has asked me to help level the inside of his currently under construction pole garage. With the bottom pressure treated 2x10 even (and level) with the highest point of the grade, the rest of the area inside is up to 12 inches lower. He naturally needs to bring the low areas up to the board. A slab is planned as well.
He's asked for some 3/4-1 inch gravel (no fines) which was mistakenly(wrong stuff) delivered to my place for a project I was undertaking some time back. It was cheaper for them to give it to me rather than pick it up. I have no problem giving him the gravel. I also would be required to transport, place and rough grade the stuff. I am glad to help him as we've assisted each other many times over the years.
With that said, I have several concerns and questions.
First: The stuff really won't compact well and he's going to have a slab poured on top within a week or 2. He shrugs off any suggestions of trouble stating he'll just patch-up any problems.
Second: I'll need to carry the stuff 1/5 mile over less than baby-bottom smooth surfaces (mildly rutted gravel drives and a somewhat variable dirt road). I can carry 1200 -1400 lbs. a trip. I have a heavy rear blade that I normally keep on for ballast but I have done loader work without it (loaded rears).
In this case I may have to leave the blade off due to maneuverability and access issues with the target structure. My big concen here is the beating my tractor is gonna take in transporting this. Is this abuse? Worse with or without the blade?
Third: Because his entrance door framing is 2-3 inches below the height of my ROPS I'd have to fold it for access. I've been on this patch of ground doing some smoothing and clean-up (it's fill dirt/rock) before the pole garage was started. It's pretty even (no 'tilty' travelling) yet I'm a bit uncomfortable about ROPSless loader work /forums/images/graemlins/frown.gif.
If I were to take this on I would transport all the material first to an area near the site, fold the ROPS (and drop the blade if used) and then carefully fill/grade the inside of the structure.
Any comments, suggestions and cautions are appreciated.
Thanks. /forums/images/graemlins/smile.gif
duke.
   / Advice on project #2
I wouldn't pour concrete over gravel... I would rather have it over a compacted subgrade.. either undisturbed soil.. or compacted fill. Only in very specific situations would you want unconsolidated material under your concrete.. and in those situations.. you do the footer and slab support differently anyway.. ( some drainage issues.. etc.. )
Compact some clean fill in ther.. use a jumpingjack to compact it.. you can rent them at most industrial tool suppliers..
Your geography and site location and conditions will directly impact what you do, etc.
Soundguy
   / Advice on project #3
He may be a neighbor and you might have helped out each other in the past, but this time, I think that what he is asking of you isn't reasonable. You are going to be beating up your tractor and in the end, if it gets damaged, is he going to pay the repair costs? I think that he should get the material delivered to his site and then get the proper tool to do the job of placing it into the pole barn. If something were to happen and the tractor flipped over, without the ROPS, you could be seriously hurt. I would be using a Bobcat type machine for this. It is the right tool for the job. Since he doesn't want to listen to reason about the use of the wrong material, I would be conveniently busy when this project is scheduled. That way, when it goes wrong, you will not be a part of it and can't be blamed for anything that goes wrong with it. It is better to walk away and continue the friendship than get involved in a project that you know won't come out correctly in the end.
   / Advice on project #4
I would go as far as getting the material to an area close to the site as you stated and let him worry about getting it inside the building. Explain to him that you are not comfortable with your ROPS down. He should be understanding with that. If not, it's your call at that point as he's your neighbor and you know him best. G
   / Advice on project #5
Seems to me you'd be best to use a trailer or get the neighbor to use a trailer and you load it. A FEL is exactly that a loader not a transport device. As to the ROPS if the ground is relatively level, and it seems it is, you shouldn't worry yourself. Yes people have died from no ROPS but that is generally by trying to pull something too high on the tractor or rolling on uneven ground. I reckon you'd be safe in a barn.
I once hired a small Kubota (to see if it was what I was after) and rolled it when the front tyre fell into a wombat hole. Fortunately the FEL prevented a full rollover (I had it in the air at the time) and was held up on a wire fence. I solved that problem by buying a tractor with larger diameter front wheels...
Anyhow it does give you quite a scare and I wouldn't recommend it.
   / Advice on project #6
I agree with the others, don't get involved with building a project that is going to fail.
Why did he want material that wont compact?
If he insists on using the wrong type of rock, have him foot the bill moving it. He got the rock for free anyway.
If if was too much effort for the rock company to come and move it, would it be allot of effort for you as well?
   / Advice on project
Thanks all.
The reason he wants my gravel and help is budget.
Is the tractor really gonna take a beating, even if I move slowly?
The only other option that I can see is to load my Ford half-ton, transport and shovel it out on site (good grief!).
duke.
   / Advice on project #8
How about having him rent a dump trailer to shuttle things over to site. You have a capable tractor but man, you are going to be doing a bunch of trips.
MarkV
   / Advice on project #9
How much gravel you talkin about? Around here it would be much cheaper and quicker to order another load and be done with it gravel of that type costs me $5 a ton....really a non isue ...by the way sand and fine gravel have 0 compaction so will not cause settling under concrete...
   / Advice on project #10
Buzz...... where is "around here"??? I looked on the map and I can't find it in any of the states. Checked the post office site and no zip code either???? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2024 JOHN DEERE 3039R LOT IDENTIFIER 91 (A53084)
2024 JOHN DEERE...
2013 Toro Workman HDX Scissor Lift Utility Cart (A51691)
2013 Toro Workman...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
