Advice On Plows Requested
   / Advice On Plows Requested #1
HamishMacCheap
Bronze Member
South Carolina
John Deere 3043, Kubota LX2610SU, Kubota L3302
I think frequently about how to do a better/more efficient job in food plot preparations. I use a chisel plow (scarifier in local terms) to break up the soil before using a disc harrow. Since the ground is red clay, it can be exceptionally difficult to break up when the ground is hard as a cast iron skillet in the summer. Also, using the chisel plow leaves clumps of dirt, some large, which require repeated passes with a disc harrow to break up.
I am giving thought to the use of a moldboard plow/bottom plow but even though I have many hours using tractors and implements, I have zero experience using a bottom plow.
I would probably use a John Deere 3043D tractor (gear transmission, 4WD, ballast in the rear tires and suitcase weights on the front) for use with a plow. The 3043D is probably somewhere above 40 HP, maybe 41 or 42. A second option is a Kubota L3302 about the same tractor as the 3043D but probably around 31 or so HP.
My desire is to turn the soil so that when I run a disc harrow over the food plots, I get the best seed bed before planting. I guess this is generally everyone's intent when they use a plow. I think less than five or so acres of food plots is a reasonable estimate.
Will either tractor pull a two bottom plow? Would a large single bottom plow be more practical than a smaller two bottom plow? I don't know how to size plows, advice on that would be very helpful.
Please include in any responses things which I have not thought to ask, which are probably more than a few.
Thanks in advance for guidance.
Hamish
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
72" General Purpose Skid Steer Bucket (A59076)
72" General...
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
THREE POINT WYLIE SPRAYER (A58216)
THREE POINT WYLIE...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
