Advice on paint/stain sprayers.
   / Advice on paint/stain sprayers. #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I recently got a sawmill. Got some lumber piling up and projects to do. Building a 15' x 30' open sided carport now. Still working on footings.
The wood for most of these projects will be yellow pine that will obviously be untreated. My plan is to stain them heavily and, well, that just sucks with brush and roller.
So I've been looking at 'airless' (whatever that means) sprayers at the big box stores. I don't know anything about them. It looks like $500 is the ballpark figure from what I'm seeing.
Would appreciate advice on these things and/or if there are better alternatives. I do not have an air compressor of any size. Just a couple of basic pancakes. It will not get daily use but hope to be building a good sized shop in the next few years and the cabin is going to need to be stained again before long too.
   / Advice on paint/stain sprayers. #2
A garden sprayer will apply stain every bit as fast as an airless and twice as easy to clean up afterwards. Airless is the cat's whiskers for large paint jobs but unless you cut pressure down to minimum you'll loose alot of stain to overspray. If you want a paint sprayer for other projects look at HVLP. You loose very little to overspray and HVLP does a great job with fine finishes like cabinets,furniture,tractors,lawn furniture and such. For a job this size I'd suggest similar to this or they have smaller and larger if you prefer.
   / Advice on paint/stain sprayers. #3
Airless sprayers are basically hydraulic pumps where the hydraulic oil is replaced with the paint you are spraying. The pump pressurizes the paint to a few thousand Psi into a reinforced hose. And at the end of the hose is a tiny orifice on a gun designed to atomize the paint into a consistent pattern. They are best for spraying latex paint and other thick stuff that most traditional sprayers won't spray, or won't do well with. I wouldn't use one with thin finishes but would go to an HVLP like jaxs suggested. So a lot depends on how thick is the stuff you want to spray?
   / Advice on paint/stain sprayers. #4
Bear in mind if you go airless (and they do work well, other than overspray) the longer the hose the more material will be wasted when you clean up. There may be more volume inside the hose than you realize.
Thanks guys.
   / Advice on paint/stain sprayers. #7
   / Advice on paint/stain sprayers. #8
I bought a Graco X5 and it's awesome, worth every penny. The only thing I don't like about it is you spend more time setting up and cleaning it when you're done than you do painting. It does a much nicer job than a roller and brush and it's way faster.
  • Good Post
Reactions: N80
Well, I tried using a garden sprayer. No go. Stain too thick. Messy and wasteful.
   / Advice on paint/stain sprayers. #10
Hopefully you didn't spend more than $20 on it and can spray pesticides with it in the future. Maybe you should use a different stain or rent an airless for a day to see how you like it before spending a few hundred and risk disappointment. Majority professional fence builders use garden sprayers around here due to having help with no painting experience.
Boss Snow Plow (A49251)
Boss Snow Plow...
Kubota RTV1100 4x4 Utility Vehicle (A49251)
Kubota RTV1100 4x4...
2024 OTHI Mini Excavator (A46683)
2024 OTHI Mini...
Wolverine SBM-12-72W Skid Steer Sickle Bar Mower (A47371)
Wolverine...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2025 Swict 78in Bucket Skid Steer Attachment (A49346)
2025 Swict 78in...
