Advice on new 424 please?
   / Advice on new 424 please? #1
onelostdogg
PA
EX3200
Hi All,
I am looking at buying my first tractor and need some opinions. I'll try to give you all the info I can...8 acres mostly wooded on a fairly steep ridge. 900ft of gravel driveway to maintain and plow, about 200ft of which is about a 20 degree slope. No mowing at all. Have a lawn tractor for that. I'm semi-mechanically inclined but not a mechanic by any stretch...can do all my own maintenence, etc. but not much more than that.
Thinking of something in the 25-30HP range with a FEL and definitely 4WD. I would eventually need something to plow with (backblade?) and would like to add a root grapple for brush removal, etc. and could make a lot of use of a boom pole. Don't want anything too large as I plan to spend a fair amount of time in the woods.
There is a Yanmar dealer about 5 miles from here and next closest is a Kioti guy about 20 miles away. I really like the things I have been reading about the new 424's but have one MAJOR (at least I think so) concern...lack of a rear diff lock. I plow with a Polaris 700 and I really do need as much traction as I can get on steep driveway which slopes downhill on north side of ridge...not much direct sun so gets pretty icy at times. I do use chains when I plow.
So is lack of locker on rear a deal-breaker? If so, what about the EX3200?
Thanks in advance for any advice.
John
   / Advice on new 424 please? #2
Sounds like the Ex3200 may fit your needs better. The physical size between the tractors is not all that different and the additional weight would probably be helpful. I know the diff lock has gotten me out of a few mud holes, so for me it is a nice option.
Thanks for the advice Red. I think you're right. Crossing the 424 off the list.
   / Advice on new 424 please? #4
I think you'd be happier with an EX3200. In the winter I plow a 925ft driveway with mine, which has two spots that are relatively steep, and I've never had a problem no matter how deep the snow is. One "must have" you'll need too, is a good set of rear tire chains, which I got at tirechains.com. I also use my tractor for clearing the brush around the fields and it works quite well with a toothbar on the loader bucket and back blade. Good luck and Welcome to TBN....
1999 FORD F550 BOX TRUCK (A52577)
1999 FORD F550 BOX...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52748)
2017 Ram 5500...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
2004 PETERBILT 385 (A52472)
2004 PETERBILT 385...
Charlotte County (A50323)
Charlotte County...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
