Loader Advice on loader
   / Advice on loader #1
greenguy296
I'm looking for a Kubota with a loader to clean out a sheep barn. The manure is hard packed so I need a loader powerful enough to break it up. I also need a tractor small enough to maneuver in a small barn so I have been looking at the B3300SU. Has anyone ever used this tractor for something like this and how did it work out. I'll also be mowing about 10 acres of pature with it. I drove one at the dealer and the loader seemed a little on the light side.
   / Advice on loader #2
If you have good skills using the FEL you would be fine, I don't know about mowing that much acreage. That might be a little small for that job.
Hope this helps
Capp
   / Advice on loader #3
You could use a box scraper to bust up the poop then shovel it up with the loader. Typically with these kinds of projects you're more limited by the traction of your tires than you are the beefiness of your loader.
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
3 pt Finishing Mower (A50514)
3 pt Finishing...
Texas Built 25' Stand Alone Inline Feeder (A50515)
Texas Built 25'...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
