Advice on buying a low hour Z840A
   / Advice on buying a low hour Z840A #1
dbaer78
nashville,indiana
kubota mx5100hst
Local fella has a nice low hour Z840a for sale. Anyone here have any experience with the Z800 series deeres? I'd like to know the good bad and ugly before I make an offer. It's a very clean unit I'm just curious about the track record of these machines. I haven't kept up on deeres zero turn mower lines. Any help would be much appreciated!
   / Advice on buying a low hour Z840A #2
I have a Z830A. Similar except air cooled. I've been very happy with mine. Very rugged, cuts extremely well, fast, so far very reliable. I've owned it for about two and a half years and have just put filters and oil in it. That said, the 800s series transmissions are not as good as the newer 900 series. If the sticks are silver/grey it's a later model, better than the earlier ones, not as good as the 900s. If it has yellow sticks, it's an earlier model, I would avoid. My mower has about 600 hours, I haven't had any troubles with it yet, but the hydros were definitely the weak spot on those machines. I'm expecting to get somewhere between a thousand and 1500 hours before I have to rebuild/replace the transmissions. You'd definitely want to keep up with hydraulic fluid/filter changes to maximize the machine's life. Which unfortunately are a bit of a pain (the filters are underneath the machine and mount internally in the reservoir for each wheel's pump/motor circuit) and not cheap ($80+ total per change between two filters and hydraulic fluid).
S Houle WD-10B Pull-Behind Hydraulic Turf Aerator Tractor Attachment (A49461)
S Houle WD-10B...
2018 RoGator 1100C (A51039)
2018 RoGator 1100C...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2007 Hyundai Santa Fe SUV (A49461)
2007 Hyundai Santa...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
