Advice needed - what do I place in a barn stall floor?
   / Advice needed - what do I place in a barn stall floor? #1
RussMan
Jefferson City, MO (central)
B3030 w/ FEL and 72" midmt
I am building a small 2 stall horse barn. I am ready to consider what type of material I should put down in the stalls. They are just dirt as of now. Do I put down a fine gravel to sort of give it some "base" as it works into the ground or just leave dirt, or sand or ???
   / Advice needed - what do I place in a barn stall floor? #2
I used a hardpack material, something like fine crushed stone w/stone dust. It packs real well. I put rubber stall mats over that. Seems to be ok.
   / Advice needed - what do I place in a barn stall floor? #3
We also put down fine crushed stone dust which was leveled, compacted and than black rubber stall mats were placed over that. The stall mats make it easier to muck out the stalls though they do add cost to the barn.
do you recall the thickness of the rubber mats? (Looks there are some 1/2" and some 3/4" on the market)
   / Advice needed - what do I place in a barn stall floor? #5
Ditto! 4' X 6' X 3/4" stall mats from TSC, laid on crushed stone. Has worked very well for our horses.
   / Advice needed - what do I place in a barn stall floor? #6
The thicker the better in my opinion. Do not butt them tight together when you lay them. Leave about a quarter to half an inch gap. If you butt them tight, they will lift from expansion during warm weather. The gap will quickly fill with debris. Some horses tend to work on the mats with their shuffling and lift the edges. The thicker mats help limit the lifting but do not prevent it. When they do, debris gets under the mat and you must pull it out, level the base and put the mat back. Having that gap helps make it easier to replace the mat. A couple of vise grip pliars will aid in moving them as a 4x6x3/4" mat weighs 100 pounds. One side of the mat will have "striations", ie; grooves at a forty five degree angle to the length of the mat. That is the bottom side. With mats, if you bed with sawdust, you can tailor the depth to the needs of the horse and cleaning is a breeze compared to dirt floors.
   / Advice needed - what do I place in a barn stall floor? #7
Crashed stones, that's what we use in our neck of woods too. Than wood shavings, the crap gets scooped 3 times a week and eventually shavings are replaced.
   / Advice needed - what do I place in a barn stall floor? #8
RussMan,
We finished refurbishing our 14 stall barn last year. Used sand to fill in the stalls and then topped that with 6 inches of a clay mixture. That was compacted and then we put down rubber stall mats. It was alot of work and up front expense however the investment pays off with regard to easy cleaning and maintenance.
Best Regards,
Terry
   / Advice needed - what do I place in a barn stall floor? #9
I would agree w/ the rubber mats. We bought a house w/ a 7 stall horse barn and the stalls had 1" rubber mats laid over dirt. We dont have horses, but we do know the previous owners raised and boarded horses for 10+ years. HEAVY SUCKERS!!
2018 Ford Explorer AWD SUV (A48082)
2018 Ford Explorer...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
2006 Ford F-250 4x4 Ext. Cab Pickup Truck (A48081)
2006 Ford F-250...
2013 ACURA ILX (A50324)
2013 ACURA ILX...
