Advice needed on Tie Rod Boot Replacement 4300
   / Advice needed on Tie Rod Boot Replacement 4300 #1
jdb
Has anyone had to replace a tie rod boot. I tore mine on an old piece of barb wire and need to replace it.
What is the best method to separate the ball joint and replace the seal.
Any advice would be appreciated.
Thanks,
JD
   / Advice needed on Tie Rod Boot Replacement 4300 #2
The best way that I found thru the years is as follows: I loosen the nut & back it off so that it is just about threaded off first. Then take 2 good size hammers & hold 1 tight up against one side of the knuckle where the tie rod goes thru & swing hard with the other on the opposite side; 1 or 2 whacks & out pops the tie rod. That easy !! Good Luck
Eric
2023 Chevrolet Express 2500 Cargo Van (A51692)
2023 Chevrolet...
2011 INTERNATIONAL MA035 ROUSTABOUT TRUCK (A52472)
2011 INTERNATIONAL...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2007 FELLA SM350 3 PT DISC MOWER (A52748)
2007 FELLA SM350 3...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
