Advance Auto Parts Batteries
   / Advance Auto Parts Batteries #1
RichZ
Veteran Member
White Creek, New York, Washington County, on the V
Kubota 4630 with cab and loader
Yesterday, my 1999 Ford F250 had a dead battery. It was the original, so I wasn't upset, until I remembered that I lent my buddy my socketwrench set, and I couldn't get the old battery out. Then I remembered that Advance Auto Parts installs batteries for free. I had been getting Interstate batteries for my trucks and tractors, but I had to replace the last two that I bought for my tractors in less than 2 years, though I always buy the top of the line battery. So, I'm now off Interstate batteries, and I bought the Autocraft Titanian battery from Advanced Auto Parts. It's got a 3 year total replacement warranty and a pro-rated 84 month warranty and 850 amps of cranking power. The price was pretty good at $79.99. The Interstates that I got only had pro-rated warranties, and were a lot more money, so I think I'm ahead of the game already.
If I had my socketwrench set, I probably would have bought the top of the line NAPA battery, whatever it is, as that's where I usually get my truck parts. For all I know, however, the Advance and NAPA batteries might even be the same rebadged battery.
Has anyone had any experience with the Advanced batteries?
   / Advance Auto Parts Batteries #2
I have a ford 850 with an advance auto battery in it. All I can tell you is that it starts the tractor... I've only had it for a couple months now, and battery is only 2ys old according to the date code.
Soundguy
   / Advance Auto Parts Batteries #3
I put one of the Advance "Silver" batteries in our '97 Accord back in the fall. It was still the original battery with 221k miles and was starting to get sluggish. Didn't figure it was worth it to get stuck at work knowing that I had used that battery a lot longer than it should have ever lasted. The first battery that I got from Advance was bad - weird bad. The ground post was made just a little too small and wouldn't allow the ground wire to tighten down:confused: Drove it to work the next day and stopped and exchanged the battery and the new one tightened up just fine.:cool: I've now put about 10k miles on it in about 5 months and it has started the car just fine in this cold weather we've been having down to -10 F.
   / Advance Auto Parts Batteries #4
Rich, many people are putting in Autozone batteries into their Ford diesels over on the TheDieselStop.Com - www.thedieselstop.com. I think they where putting in the GOLD model. I have not checked over their lately to see if there have been bad experiences. I was looking a few months ago since my batteries in the F350 are over 5 years old and still cranking in this cold weather we have been having lately. I have never had the OEM batteries last more than 2-3 years.
When I replace them I'll look at the Motorcraft brand again, Autozone and what I can get via the Farm Bureau. I have 80,000 miles on the origional brakes. They still seem fine but I think I'm going to replace them in the next 4-6 weeks. I think I'll put Motorcraft back on since they have worked so well.
There was a review of batteries by Consumer Reports and they like the Autozone product.
Later,
Dan
   / Advance Auto Parts Batteries #5
I have AC Delco in both CUTs. There was a long thread somewhere that gave the Delco pretty high marks and bashed the Interstate. Two years and so far so good.
   / Advance Auto Parts Batteries #6
There are so many variables when it comes to batteries that it is hard to judge from a small sampling of data. These variables include:
How old was it when you purchased it?
How long does it sit between charges?
How much vibration is it subjected to?
How cold was it when it "failed"?
Do you leave a charger connected?
How much leakage current does you vehicle pull when off?
Has it been run down by leaving lights or something else on? (This can damage a battery, particularly if it is left discharged for a long time.)
How many extra CCA does it have for the application?
Is it parked in a garage?
Is your vehicle charging system working properly?
Are the battery terminals clean and tight?
Do you clean the top of the battery periodically?
Does the vehicle idle a lot with many electrical loads turned on.
I am sure there are other variables.
My recommendation is buy the biggest battery (CCA) that will fit in your vehicle and keep a float charger (not trickle) on it when not in use. Count yourself lucky if you go five years.
   / Advance Auto Parts Batteries #7
Just my opinion, but I expect more than 5 years out of a battery.
I had a JD battery in my 850, it needed replaced after 6 years and I was disapointed in it. I'm running an Advanced Auto battery in it now. Will have to see how long it will last.
I bought my pickup truck used in early 1996 ( it had a Diehard battery in it when I bought it), I just replaced it this past summer (2006), I ran for 10 years on that battery.
The battery in my Kioti tractor has been in there for 6 years. I hope for/and expect a couple more years out of it..
   / Advance Auto Parts Batteries #8
As I said, there are many variables. Station batteries in controlled environments last up to 15 years if memory serves me right. I have had batteries bad when new.
Are you doing anything special to make them last like you do?
   / Advance Auto Parts Batteries #9
No. I put the battery in, put some grease on the terminals so they don't corode and I go.
   / Advance Auto Parts Batteries #10
A battery protected from the elements will last lots longer. The battery in my Buick is under the back seat.(At least that's what the manual says) I've never seen it. It's seven years old now. Being there it's protected from vibration, heat from the road and engine. I guess VW had a good idea with their battery under the seat if they could have just kept the battery from falling through the hole the battery acid ate in the floor.
2011 FORD F550 CREW CAB (A50046)
2011 FORD F550...
2025 Man Basket Forklift Attachment (A49346)
2025 Man Basket...
NEVER USED FECON 74in Deck Mulcher FDM74 (A50397)
NEVER USED FECON...
2017 Ford Focus SEL Sedan (A48082)
2017 Ford Focus...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A50397)
Adams Load Out...
2019 CATERPILLAR 249D SKID STEER (A50458)
2019 CATERPILLAR...
