adjustingthe shuttle shift?
   / adjustingthe shuttle shift? #1
Scratchnbell
Fish Camp,California
New Holland 2001 TC40d
Is there a way to adjust the shuttle shift to make it more positive.
Mine just barely feels like it engages. It also doesn't engage all the time. I almost have to feel it into place in the forward position.
Bob
   / adjustingthe shuttle shift? #2
Bob, you can adjust the cable under the tractor so that the cable gets longer or shorter,also make sure the cable is not binding anywhere,
Tommy
Affordable
Tommy,
Is there some kind of a stop that can also be adjusted? It feels like it should be able to "slide" into the forward position a little bit more.
Bob
   / adjustingthe shuttle shift? #4
Bob the adjustment is in the cable,if you look under the right floorboard you will see the lever that the shuttle shift cable connects to, that is the only movement, so if you think it needs a little you need to lenghten the cable some.
Tommy
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2020 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A53426)
2020 FREIGHTLINER...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
Ford F-450 Utility Truck (A53473)
Ford F-450 Utility...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
Landhonor RSB-14-80W, 80" Rock Bucket (A52384)
Landhonor...
