adjusting wood chipper feed roller speed
   / adjusting wood chipper feed roller speed #1
1720BlueBell
Dolores, Colorado
Ford 1720
My Bandit 250 wood chipper has some hydraulically powered functions. Specifically, the two horizontally oriented feed rollers are fed by a single line with no regulation feature. I would like to be able to control the speed that these rollers turn. If I could adjust them to turn more slowly when pulling in larger diameter wood and more quickly when being fed smaller diameter brush, I believe the efficiency of the machine would increase.
Would a flow control valve be the thing to install in the hydraulic line ahead of the directional control valve? If the flow is reduced. do I still have the full "pulling" power of those feed rollers, or does actuator power also drop off when flow is reduced? Am I looking for something other than a flow control valve?
I realize this 12" capacity chipper is not a tractor, but...I pull it behind my Ford 1720. That counts, right?! Ha!
Thanks for your consideration.
Roger
Thank you J.J. Now that I think of it, that's a valve that I've seen used on a big Vermeer chipper for the exact purpose that I need. Next item: a hydraulic winch for my chipper.
J.J. Thanks again. Electric rather than hydraulic may be the way to go; I'll have to give it more consideration. As I use the chipper commercially, I'll be looking for a more robust winch. At times I pull heavy trees back against their lean when felling them. I also winch heavy logs uphill to the truck. I now can see the beauty of an electric winch: with mounts on my chipper, on my tractor, and on my big chip truck, I can quickly and easily move the winch to whichever machine I am using that day. One desirable feature for me is rope, such as Amsteel Blue, rather than cable for winch line.
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2005 Freightliner Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Freightliner...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
Bobcat B950 Skidloader Breaker (A50774)
Bobcat B950...
