Adjusting Tracks on Mini Excavator
   / Adjusting Tracks on Mini Excavator #1
andrewj
Platinum Member
South Carolina
JD 5105
I have a Komatsu PC 20 that threw a track today. I got it back on but Im not sure about the proper tension as I had given it some attention just last week and thought the tension was correct.
Can someone give me the rule of thumb on this? I don't have a manual.
Hopefully soemone from the morning crew this fine tuesday will have some info!
   / Adjusting Tracks on Mini Excavator #3
I have a Bobcat X320 and I have the book on it and it says 2.25-2.50 between the frame and the top of track, of course that is with the machine off the ground
   / Adjusting Tracks on Mini Excavator #4
Usually there is a sideways 8 printed on the rubber inside of the track that indicates the seam, you want that over the idler to measure.
   / Adjusting Tracks on Mini Excavator #5
It will depend if the track is steel or rubber
My kx 71-2 kubota is 40mm for steel and a little under half that for rubber as
stated above this will be with the track off the ground and if rubber the join in the right place
   / Adjusting Tracks on Mini Excavator #6
Hey fixit how do you like the kx71? I was looking at one a while back but I may go with the KX 91 but it is going to have to wait until the economy picks up some, it is kinda slow at the moment
   / Adjusting Tracks on Mini Excavator #7
Hi Degolyerent
I have found it very good it has been very reliable up till now
It has plenty of power for its size and the 4 cylinder engine so it is a little smoother and quieter than the 3 cylinder units
I bought it a little over 2 years ago now to do some ground work for my new workshop and store shed 30x90 and just cant stop finding jobs for it
Once i finish draining our pasture i am thinking of making an hydrualiic fence post driver that will run off the hammer pipes
   / Adjusting Tracks on Mini Excavator #8
Rule of thumb with rubber tracks is 1/2" play per every tonne weight of machine, ie 3 tonne = 1 1/2" lateral movement
2018 KENWORTH T680 (A45046)
2018 KENWORTH T680...
Unused 84" Bucket Attachment (A42021)
Unused 84" Bucket...
2017 Ford Expedition SUV (A42744)
2017 Ford...
2009 BMW 750i Sedan (A42744)
2009 BMW 750i...
2020 MACK PINNACLE (INOPERABLE) (A45046)
2020 MACK PINNACLE...
New Holland TN65S (A44501)
New Holland TN65S...
