Adjusting drive disk on snowblower
   / Adjusting drive disk on snowblower #1
Bigfinn
WI
NH TC 29 4wd, Ford 1210 4wd
hello, I gought a used dynamark snowblower, and I need to adjust the drive disk to more positivley engage the perpendicular driven disk. Any tips? Is there an adjustment nut behind the disk? thanks.
   / Adjusting drive disk on snowblower #2
I believe the pressure on the drive disk is determined by the tension on the cable from engagement handle. There should be a threaded rod/stop nut adjustment on one end of the cable which can be adjusted to tighten it. The belt tension for the engagement of the impeller can also be tightened by this method.
2013 Freightliner M2 106 Altec AA755 55ft Bucket Truck (A51692)
2013 Freightliner...
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
iDrive TDS-2010H...
