adjusting clutch one e2004/mf 1030
   / adjusting clutch one e2004/mf 1030 #1
agcomike
southern states
Hinomoto e2004 aka 5020
1) I was wondering on left side where the clutch pedal is what does that yellow decal state? (looks like something about adjusting or something?)
2) Need info on clutch/clutch pedal adjustment
3)i noticed my pto shaft moving everyonce in a while (1/4-1/2 turn at a time maybe normal?) when the pto lever was off maybe related to needing clutch adjustment?
4)also have a transmission leak at the front axe u-joint area where the driveshaft comes into the front axle it's spilling trans fluid when i park on slight incline is the seal on back of trans or in front? also do you have to remove front axle to get shield/driveline off?
thanks
   / adjusting clutch one e2004/mf 1030 #2
2) There will be a turnbuckle on the rod from the pedal to the clutch housing.
3) PTO shaft will move when not in gear. You can stop it with your hand. (not recommended)
4) Just take the pin out of the front axle and drop it down, move it slightly forward.
I don't know about the decal.
Eugene
   / adjusting clutch one e2004/mf 1030 #3
If you can attach a legible photo of the decal, I'm sure you can get it interpreted. I can get it done. It's probably about latching the pedal down for storage, or depressing the pedal to enable starting, if these apply.
Payment Terms (MUST READ) (A50774)
Payment Terms...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2008 New Holland B110 MFWD Loader Backhoe (A51039)
2008 New Holland...
2015 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2015 MACK GU713...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
