Adjusting a 2 stage 1050 clutch?
   / Adjusting a 2 stage 1050 clutch? #1
qstott
Elm City, NC
'65 110 JD, 445 JD, 4720CabJD
I have a 1050 JD with about 3100 hrs on it. I bought it a couple of months ago. My most recent purchase was a finish mower. When I first got it, I could engage the PTO with no scrubbing. When I hook up the mower, it scrubs each time I try to engage the PTO. The first stage works fine, no gear scrubbing at all. IT appears that the second stage is not releasing. With no implement behind it, I suspect the PTO shaft does not have enough resistance to cause the PTO to scrub when engaging at an idle. When the mower is hooked up there is more resistance. The 1050 has a 3 cyl yanmar in it. I have a shop manual and it shows to adjust the PTO clutch with the tractor split. I have a small inspection plate on the side of the flywheel housing. When I remove the plate, I can see the PTO adjusting bolt, but there is a lock nut next to the pressure plate housing that I don't have access to. Anyone know any tricks? Or am I going to have to bite the bullet and split the tractor? The clutch pedal is adjusted to the proper height now. Thanks in advance for your help!
Yep, I had to split the tractor. It was not as bad as I thought it would be. You may be able to find the thread by searching the board.
   / Adjusting a 2 stage 1050 clutch? #5
I have a 950 with 2100 hrs that had the same problem. Turned out to be worn linkage components. The yoke that releases the clutch has some "nubs" on it. They were worn flat. The clutch pedal shaft and arm was badly worn. Since they had it split anyway, I had them replace the clutch and all linkage components. Clutch may have been OK, but with that many hours I figured it better to replace it while it was down.
2013 ACURA ILX (A50324)
2013 ACURA ILX...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A51219)
2020 KENWORTH T680...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2015 Ford F-150 4WD (A51039)
2015 Ford F-150...
2020 Chevrolet Tahoe SUV (A48082)
2020 Chevrolet...
