jimg
Veteran Member
- Joined
- Jun 5, 2003
- Messages
- 2,039
Just got my TC24D and have some questions/comments about the 3pt hitch setup. The tractor was delivered with the mower attached. I made the assumption (incorrectly I believe) that it was ready to use. Actually I think it was mostly ready.
Anyway...once I started mowing I decided some areas would be best attacked by backing into them. When I tryed this there was some sway to the mower and if not careful the mower would run back and forth being very difficult to control. With some practice I managed to keep the sway to a minimum. Later, after some reflection and observation of the hitch, I concluded that the stabilizer turnbuckles werent tight enough to prevent sway. So...should they be so tight as to prevent all sway? If not how much is acceptable? It seems though sway is an expected component b/c the lift arms/top link all have ball sockets. In fact is some sway neccessary?
Before I could finish mowing I needed to move the snowblower which afforded an opportunity to test my hitching skills. My initial assumption was that the setup for the mower wouldnt work w/ the blower. This turned out not to be the case!! Everything lined up nicely. Is this common? Can a single setup be expected to accomodate most/all implements?
In hooking up the blower I found the lower hitch pins wouldnt fit thru the holes in the ball sockets of the lift arms. Comparison showed them to be ever so slightly over size. I think they're metric as the unit was made in Italy. Is this common for offshore implements to come with metric pins? It turned out not to be a problem since the mower pins fit.
In fact my dealer will drop off a new set of pins.
Finally, I was surprised how easy it was to hook up to the 3pt. In fact it was trivial. Before I got my tractor I was thinking along the lines of quick hitches and aftermarket telescoping arms. Now Im thinking I wont really need them.
jimg
jimg
