Adjusting 3930 front axle width
   / Adjusting 3930 front axle width #1
Jason280
Ga
Kubota L4330
I need to widen the front/rear tires on a Ford 3930 a little for proper spacing with a cultivator. I pretty much know what I have to do with the rear, but I'm not 100% on the front. Its a 2wd tractor, and it has these two bolts through the front housing. It also has what appears to be some sort of set screw holding in the drag link/tie rod (not sure what its called). Is it as simple as jacking up the front, removing the two bolts, loosening the set screw, and sliding the inner portion out to the next set of holes?
Another site linked me to a manual, which pretty much shows the steps...what are the odds I can do this without having to adjust the toe-in?
   / Adjusting 3930 front axle width #2
The design of the unit is such that toe in will not really be affected. The tie rod and steering cylinder extensions have notches that correspond with the axle bolt spaces. once you get them moving (that's going to be the fun part) you will see what I mean. Axle assemblies move one bolt hole, rod extensions move one notch,, etc.
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
Case IH 1020 Platform (A50514)
Case IH 1020...
UNUSED RAYTREE QUICK ATTACH VIBRATING BUCKET (A51244)
UNUSED RAYTREE...
