additives for front axle leak
   / additives for front axle leak #1
al121hp
jd 4700
I have a jd4700 4wd. There is a slight leak in the front axle. Are there any additives that are safe to add to the front end to help stop/slow down the leak until I have time to get it fixed?
   / additives for front axle leak #2
I had a leak that would be 8" wide overnight on the floor. I was told to replace the front end oil with Lucas Hub oil that has a stop leak in it. I did that and ran it for a couple hours moving snow. Next day the leak was 2" on the floor. Next time I did a little back blade work for an hour or so and the next day the leak was gone. That was 60 days ago. I am now a Lucas hub Oil fan. :thumbsup:
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
1267 (A50490)
1267 (A50490)
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
2011 TRAIL-EZE  TE80HT48 HYDRAULIC TRAIL (A50854)
2011 TRAIL-EZE...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
