Additional Gauges
   / Additional Gauges #1
Midwest C6
Southwest Minnesota
John Deere 4044R
Hello. New member, been reading for years. I own a 4044R. I am looking for an aftermarket gauge package that can read CanBus signals from the Factory Deere system. Can anyone advise if this is available?
All I can get from the display is fuel, temp, tack, speed, and regen info. I would like oil temp, oil pressure, hydraulic temp, volts, etc. I assume the factory system is reading this info via factory sensors, and sending those signals, but the display is not set up to show.
Obviously you can get these for cars and trucks, but I could not find for John Deere.
   / Additional Gauges
I will amend my question since I did not receive any feedback. Anyone with a service manual for the 4044R that may have a schematic that would show where I can plug in and get a J1939 signal?
   / Additional Gauges #3
:welcome: to TBN
Doubt many understand about CanBus signals to interpret just what you are after, as well as you understand. ;)
Might it have to do with how a mechanic can plug a computer into the connector under the dash and check for errors and diagnose problems?
The second post, I'd suggest if no one has the schematic you are looking for, that you get yourself the service tech manual for the 4044R.. it may come in handy for other things in the future.. I wouldn't want to be without the service tech manuals for my "things"..
Your location in your profile would be helpful,
   / Additional Gauges #4
There are companies that offer programmers for the larger John Deere’s, they might have a plug and play monitor that will work for you.
   / Additional Gauges #5
Your local JD Dealership (Service Dept.) should be able to provide that schematic for you, and free of charge (at least, my Dealership would).
I know that my blokes would be happy to discuss what I'd be considering too.
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2004 Honda Accord Sedan (A51694)
2004 Honda Accord...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
Mitsubishi Mini 2WD Truck  (A52384)
Mitsubishi Mini...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
