adding to YM200 hydraulics - need diagram
   / adding to YM200 hydraulics - need diagram #1
MVHF
Yanmar YM2000
I am adding a loader to my ym2000 and need to plumb in a return from the power beyond on my control valve.
Can someone recommend a source for diagrams of the ym2000 hydraulics that might reveal the best location for a low pressure return line?
thanks
The method they describe is how I first installed the valve and the valve started leaking on the intake side. I asked around and was told that was due to pressure build up when I used my 3-point. I was told that most factory installations use a valve fitted with power beyond to avoid this situation.
the power beyond valve requires a low pressure return as well as the pass through high pressure connection as shown in the diagram at http://yanmarowners.com/YANMARLOADER.htm.
   / adding to YM200 hydraulics - need diagram #4
What brand of loader are you using? It could be that some valves are not designed to be used this way.
Aaron
Parts@HoyeTractor.com
(940)438-0386
It's a home grown loader. The valve I was using was something I found on the net. couldn't make out the brand. Since then I've purchased a new Prince valve that is power beyond capable.
2017 TAKEUCHI TB290 EXCAVATOR (A51246)
2017 TAKEUCHI...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
UNUSED AGT MX MRT14 STAND ON SKID STEER (A51247)
UNUSED AGT MX...
MURRAY GAS PUSH MOWER (A51248)
MURRAY GAS PUSH...
