Adding third valve to Joystick
   / Adding third valve to Joystick #1
Nicholas lewis
Massey Ferguson 1533
I have a 1533 , there aren't any hard lines going to the joystick to help locate the power beyond line , I wanted to tee off the lines right at the back of the joystick if that is possible for a third valve.
Appreciate any Help
   / Adding third valve to Joystick #2
If you have 3 lines going to the joystick valve, you're already have power beyond setup. If not, then we need to figure out how the system is plumbed.
You can't Tee any line other than the Tank line on a open center system.
We also need to know what kind of valve are you planing to use. If it's a solenoid or a mechanical actuated valve.
Would like to use a mechanical valve to keep the price down , there are 4 lines that go to the loader and 3 coming from the tractor 20191201_103404.jpg20191201_103404.jpg20191201_103404.jpg
   / Adding third valve to Joystick #4
Ok, so you have power beyond on the loader valve already hooked up.
You need to get the valve you want plus the Power Beyond plug/sleeve for the valve you're buying. You'll need a couple hoses and fittings.
Then you take the Power Beyond line from the loader valve to the IN port on the new valve. You might need to take the cover of the loader valve to confirm what line corresponds to what. It should have a marking like PB or C.
The Power Beyond port of the new valve with the PB sleeve, will then feed the rest of the tractor hydraulics (3 pt and remotes).
The Tank lines will be Tee'd together.
   / Adding third valve to Joystick #5
I'll take a shot.
One line is "power" to the valve. One line is "tank return" leaving the valve and back to the sump. One line is "power beyond".
The power beyond line will go to the 3pt system of the tractor. First thing the pump powers is the loader valve. If no useage there it delivers that power to the 3pt system.
The power beyond line is what you will power your add on valve with. So it becomes the "power" line to the new valve.
The "tank return" line out of the new valve can be T'd into the loader valve tank return line if that's handy.
The "power beyond" line out of the new valve will then go to your 3pt system.
Hope that makes sense?
   / Adding third valve to Joystick #6
I was typing while you were. :D
Hopefully between our two descriptions it will make sense to him. :)
   / Adding third valve to Joystick #7
Welcome to TBN Nicholas. Nice shop. Nice Deer. I think your concrete saw overheated. :D
   / Adding third valve to Joystick #8
I agree. Should be enough info to get the job done.
Yours might be easier to understand. Since English is not my main language, sometimes I can't express my self very clearly. :thumbsup:
   / Adding third valve to Joystick #9
You speak my language much better than I speak yours!!!! :cool:
Thank you for the help the third valve will be able to power two cylinders that only have inlets with no outlets20191201_111501.jpg20191201_111741.jpg
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
Kewanee 15' Disk (A50515)
Kewanee 15' Disk...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
Shopbuilt Snow Plow (A50515)
Shopbuilt Snow...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
