Adding second rear remote and one to the front on jd 3320
   / Adding second rear remote and one to the front on jd 3320 #1
600xc4me
La Crete Alberta
JD 3320
I have a 2014 3320 that I bought with one factory rear remote. I got the dealer to run lines to the front as well when i bought it, for my grapple and what not. But now I installed a hydraulic top link in my 3pt hitch, and I don't want to always have swap hoses around in the back there according to what I want to run. So here's what I would like to do, I'm not just sure how or what it's gonna take.
I would like to find a handle of some kind, that I can install a slider switch into. Like what you find in an excavator to run the thumb or tilt bucket. Install that on my 3pt hitch lever to run the tilt back there. Then run another set of remotes to the back for other uses, and keep my one set currently in the front. I want to run these two off of the loader joystick toggle, and use the third little button to select between the two. I see the block where the rear couplers come out of has plugs in it, making me think I can run another set of remotes through there, and run those two remotes off the joystick. I could do that and run the hoses to the front for the grapple off of one of those, but that's messy and not how I would like it. Any advice for me to accomplish what I want and keep it nice and clean?
   / Adding second rear remote and one to the front on jd 3320 #2
On my 2008 3320 I had the electric diverter valve kit installed which added 2 more sets of outlets to the rear for the top and tilt cylinders.
Then you had three sets to the back? How do you control them? Also not sure if that kit will work on mine, they resigned the whole hydrolic system in 2011 I'm told. Still trying to wrap my head around how this might work. I found I can add two manual valves that come up from the back, to add another two sets. But I would like to control them via the joystick toggle, not a manual valve.
   / Adding second rear remote and one to the front on jd 3320 #4
John Deere has a manual 4th & 5th rear SCV kit LVB26035 & an electric 4th & 5th SCV kit LVB25507 for the newer 3320s.
Thanks! I have seen the manual one, and I'm starting to think that's the way I'm gonna have to go, but I'm not quite willing to give up my idea yet. Lol I just don't know enough about hydraulics to know if its possible.
I looked into the LVB25507 diverter kit a little bit as well, but how I under stand it is I would be using my loader joystick controls to run the 4th and 5th functions. And I'm not to interested in doing that. I can see that being awkward for running my rear top link and other rear attachments.
What I want is not offered by John Deere. So it would have to be a custom setup, I'm just not sure how to go about it and what I would need to do. :rolleyes:
   / Adding second rear remote and one to the front on jd 3320 #6
Contact Brian at fitritehydraulics and he will fix you up.
valves
Perfect thanks! Sent him an email. Going by his website I'm sure he'll be able to help me out.
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
Caterpillar 279C...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2015 FORD F-250 SUPER DUTY (A52472)
2015 FORD F-250...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
2013 PETERBILT 388 (A52472)
2013 PETERBILT 388...
