Adding rust inhibitors vs. new Anti-freeze
   / Adding rust inhibitors vs. new Anti-freeze #1
Bob_Young
Veteran Member
North of the Fingerlakes - NY
Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
My old Ag tractors are protected with permanent antifreeze. As things currently stand, none of them see much use over a year; maybe 20 or 30 hours tops. Rather than drain and refill with fresh anti-freeze every 2 years, I've taken to adding cooling system rust inhibitors periodically. It's quick, simple, less messy and less expensive.
I wondered if anyone else here is taking this approach or if anyone has experience, good or bad, with using corrosion inhibitors in place of fresh antifreeze.
Bob
   / Adding rust inhibitors vs. new Anti-freeze #2
I bought a VW that was 5 years old. The VW manual says it's permanent antifreeze, there for the life of the car. Well, I changed it anyway. It was bright and clear, no evidence of any degradation at all.
Checked my maintenance books on both my Toyota and Benz. Been 3 years since I changed theirs. Bought new antifreeze: $23/gallon @ Toyota and $25/gallon @ Benz. Both drained beautiful and bright and clear, Toyota redish clear; Benz a little yellowish clear.
So, based on my experience and the current high price of antifreeze, I'm going to 5 year change intervals on anything with long life antifreeze in it.
If you go with the standard Prestone or other non-so-clear-to-begin-with, dark-color brands, you might want to continue changing at 2 years. Buy quality at $23-25/gallon and go to 5 years. Done similar on my engine oil. Have gone to yearly changout or approximately 6k+ miles, but using $5-6/qt. Mobil 1 vs. $2/qt. dino stuff. It's just easier on my getting-old bones, too.
Ralph
   / Adding rust inhibitors vs. new Anti-freeze #3
Bob, I tend to agree with you. Unless the coolant is discolored or rusty, adding rust inhibitor periodically instead of changing as often it will do virtually the same thing. I did that for years with several vehicles I had, and they stayed nice a clean.
It would be best though if you used silicate free antifreeze, like one of the newer 150,000 mile, 5 year brands. This applies to most engines, but for some reason some mfgs (like Ford in the earlier PowerStrokes) don't recommend these coolants due to potential issues with rubber o-rings.
The reason for using this coolant has something to do with silicate drop out, which is eliminated by using a silicate free product. I believe that it is the silicates that often plug up radiators, heaters, etc, if the antifreeze isn't flushed regularly.
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
