Adding return to tank line
   / Adding return to tank line #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Starting a new thread just for this question. Open center system, added a spool valve that needs a return to tank.
I wanted to make the line as short as possible by T-ing into a fitting at the tank, to avoid long hoses/hardlines and an "uphill" run. Now that I crawl under there, I find the space very limited and likely a real PITA to T into. And, I runs "uphill" about 6 inches anyway. I did not want to run a hose or line from the rear to the front loader return line and T into that at the valve, mainly because of the length and about a18-24 inch "uphill" run.
I've touched on this before but wanted to again, to see if there are any "hydraulics" reasons that argue for one over the other?
I have run across an older post for adding a thumb, which shows a T at the FEL return to tank line so it appears that should work fine.
However, without taking apart the existing stuff, can't identify the fitting I might need.
Can someone identify the threads on this item: "75595-63410, Plug, Orifice"? It thread into the tank return on the FEL (TL421). As ususal Kubota does not provide any information on the fitting and no cross has turned up s far.
Perhaps in addition to or instead of the part above, how about specs for this one "75550-61900, Elbow adjustable" or "75540-61910, Elbow, adjustable"? Those thread into the part above using an O ring, with a backup washer and nut. I take that to be an SAE ORB.
I guess I can just break down and disassemble it and take it to the hydraulic shop, as I have to get hoses made up anyway.
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
Quick Attach Pallet Forks (A47384)
Quick Attach...
PALLET OF WALL PACKS (A51244)
PALLET OF WALL...
SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-2PS...
