Adding remote valve
   / Adding remote valve #1
thesle
ms
245 case/international
Thinking of installing a dump cylinder on my dirt scoop My tractor is Case/international 245, 21hp 4.5gpm hydraulic.
The output line runs from pump to power steering then to 3 pt power lift housing. My question is can I tee into this pipe with a suppression fitting for the hose to the remote valve. I,m thinking a 1.5 bore ,10" stroke will work to dump the scoop. Thanks for any Info.
   / Adding remote valve #2
Just insert the new valve between the PS and the 3pt.
Valve should have a PB port.
No tees in the pressure line.
Thanks much JJ simpler than I was thinking. Have a blessed Thanksgiving. thesle
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A55787)
2025 GIYI VR66...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2017 TAKEUCHI TB240 EXCAVATOR (A52705)
2017 TAKEUCHI...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
2018 Doosan DL220-5 Articulated Wheel Loader (A55787)
2018 Doosan...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
