Adding remote hydraulics to FEL
/ Adding remote hydraulics to FEL #1
design
Southern, NH
M5400
I would like to have an extra circuit on the FEL. What are the possible ways to do this?
Is it possible to plumb the rear remotes to the loader frame? Has any one done this? How do you set up the system to allow for FEL removal?
What are the other ways to add one additional hydraulic circuit plumbed to the QA plate?
I have a fisher plow that is mounted to a QA plate and I now want to plumb in the left/right swing.
Design
/ Adding remote hydraulics to FEL #2
Do some searching in the Hydraulics forum, this is discussed OFTEN:D
Short answer is yes, you can run hoses from the rear remotes up to the loader arms, OR you can add a electric diverter or valve to have control from a button on the joystick.
Be sure to read the grapple threads also as they have the same setup need to operate the grapple
Search terms like:
diverter
WR Long
grapple
4n1
remote
/ Adding remote hydraulics to FEL #3
Kubota used to have a kit to add remote hydraulics to the loader frame up front. I haven't been a mechanic for them for about 6 years now but I installed a lot of them for those dairy farmers out where I was working. They had quick attach buckets and would run all kinds of implements up there that needed hydraulics. Post hole diggers, mowers, post pounders. Dairy farmers have more stuff than I had ever imagined. The Amish dairy farmers in that area were even better. We made our own steel wheel for a lot of their tractors and most of htem had to run them but it was amazing the other high tech gadgets they would use. As long as it didn't have to plug in to a wall. It could plug into a hydraulic port though.
2007 Ford F-150 Pickup Truck, VIN # 1FTRF12247KD16090 (A64194)
2007 Ford F-150...
2004 Ford F-550 Single Cab Flatbed Truck, VIN # 1FDAF56P94EC72605 (A65563)
2004 Ford F-550...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
