adding rear remotes to my tractor
   / adding rear remotes to my tractor #1
andrewj
Platinum Member
South Carolina
JD 5105
I was not sure whee to put this in the JD forum or here - I have a JD 5105 with a loader joystick. I'd like to add 2 rear remotes. I went to the dealer and saw how they are rigged up, so it looks do-able to me but I will definately need a little guidance. anyone have any guidance, or direction?
   / adding rear remotes to my tractor #2
I'am in the same boat. I have a jd 770 with power beyond think of hooking into a vavle and mounting on fender. What kind of setup do you see at the dealer. thanks tim
well, it was a small black metal box, bolted or screwed onto another black box, with thingy's coming out, and a long tube like gizmo going forward, and four lines with colored ends going backwards. there may have been some glue involved as well. i'm sure I can handle it.
seriously, the one I looked at had the loader valves already mounted, like my tractor has. it appeared they had mounted an additional valve body on top of the loader valve.
   / adding rear remotes to my tractor #4
Sounds to me like it may be a Fasse Valve set up. Check out Fasse.com or Vandminc.com. Both companies offer packages to do what you want, some up to 8 remotes.
Ron
   / adding rear remotes to my tractor #5
20060206
With my adjustable top/side links, my dealer installed a Fasse valve (electric, seems to work well), though the wiring into my cab turned out messier than I would have liked.
It was on a NH TN90F (80 PTO hp machine designed compactly for orchard/vineyard use), which already had 2 factory remotes in back.
What I wish I had done, though, was to install the 3rd available factory remote before the Fasse was put on. Since the Fasse takes up one of my old remotes I am now down to one without popping off the links, etc.
The 3rd rm can still be done, but at much higher cost now due to having to disassemble everything /forums/images/graemlins/frown.gif.
Just some future-leaning advice in case it is applicable to you.
Jim
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
8 Yard Commercial Dumpster (A49346)
8 Yard Commercial...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2005 International 4300 LP 14FT Flatbed Truck (A48081)
2005 International...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A50505)
2000 MACK RD688...
