Adding rear remotes, it this control valve ok?
   / Adding rear remotes, it this control valve ok? #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
I'm looking to finally get my remote hydraulics installed on my Yanmar, and need to finalize a valve. I have access to a Eaton 31920-CCW. Will this Valve do the trick? Here is a general PDF on the series of valves and a pdf of the info the valve itself.
Eaton Control Valve 31920 CCW
Specific details
Thanks,
Rob
   / Adding rear remotes, it this control valve ok? #2
Specific details
Thanks,
Rob
On the presumption that your Yanmar requires open center this valve should work fine.
My Yanmar requires open center valves.
Thanks,
Rob
JOHN DEERE TS LOT IDENTIFIER 138 (A53084)
JOHN DEERE TS LOT...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
(1) 330 GALLON POLY TOTE W/ CAGE (A51248)
(1) 330 GALLON...
