Adding rear remote lines to CK35
   / Adding rear remote lines to CK35 #1
Kilo69
Coldstream Nova Scotia Canada
Kioti CK35 HST
I'm wondering what all is involved in adding remote lines to my CK35. From what I can tell it doesn't seem that hard to add a couple lines with quick connects and run them to the rear of the tractor.
Is there any tricks or things I should know before I get into this?
   / Adding rear remote lines to CK35 #2
Are you adding the rear remote kit which has the valve with lever next to the 3pt lever or are you adding what they call a hose kit? Either way, I had installed the hose kit first because that's what the dealer said I needed for the bh. It worked but it's a pita to crawl under the tractor and turn the valve shaft each time but it was cheaper. After some choice words for about the twentyfith time, I installed the two rear remotes. They make life so much nicer. Either are not hard to install. You'll have to take the seat off to access where the valve bolts to the side of the case. The Kioti kits I installed had instructions with them and it's all fairly straight forward.
   / Adding rear remote lines to CK35 #3
It involves $450 (here anyway) for the kit, the install is apparently not very hard. My dealer added the second set when they installed my cab, so I didn't do it personally.
   / Adding rear remote lines to CK35 #4
If anything like the CK30, then not difficult at all. Take the seat off, take your time and done in a matter of a few hours no sweat.
David
2013 FORD F550 SHUTTLE BUS (A52576)
2013 FORD F550...
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
