Adding Rear Remote Kubota L35
   / Adding Rear Remote Kubota L35 #1
FF110
North Carolina
John Deere 110 TLB, John Deere 4230, Satoh 650G
I am fairly new to hydraulics but am learning a lot through this forum, so any help would be appreciated. I am going to add a set of remotes to the rear of my L35 and have a valve that I want to mount beside of the FEL control. I am trying to figure out the best way to tap into for the in port. Originally the plan was to mount the valve on the fender, but when I got it in I did not like the placement there so I decided to move it. I was going to tap inot the line for the backhoe at first but since moving the valve I am wondering what my options are. I do not want to run my in and out hoses to the back to tie into backhoe lines if there was some way to tie into the FEL lines. Any suggestions?
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
