adding rear hydraulics
   / adding rear hydraulics #1
dvan1966
NW. Ohio
Kubota B6200DT
I have a Kubota B6200D with a FEL. Rear hydraulics was an option but dealer says kit is no longer available. Can I just tee off of the front ports that are for the loader and run them through valves and to the rear? I want to add power angle to my rear blade and maybe a hyd. top link.
   / adding rear hydraulics #2
Hello - and welcome to TBN!
There's lots of after market valves out there. I'm no expert, but if you'll do a search for "power beyond" you should find lots of ideas about hydraulic access. Good luck!
   / adding rear hydraulics #3
I'm not a hydraulics expert but.....
Hydraulic circuits must be in series. ie one after another. If you use a T as you described the circuits will be in parallel and neither will work since the pressure will by diverted by the other circuit.
   / adding rear hydraulics #4
Tig is right in that you can't just "T" off.
Do you have any other valves besides your fel loader valve? If not, you need to feed your new valve from the power beyond port on the fel valve. You will probably need to get a power beyond sleeve that fits into that port, if it's plugged off now. Run a hose from there to the power "in" on your new valve. The "exit" of your new valve, or return to sump, can be "Teed" into the return to sump or tank ... same place your fel valve is returning to now (to tank).
   / adding rear hydraulics #5
There are pictures in the gallery of how my remotes are plumbed if that helps
   / adding rear hydraulics #6
There are lots of option, you just have to pick the ones that suit your needs and wallet. With a little mechanical know how, you can save tons of money. drop me a PM if u have any ?
   / adding rear hydraulics #7
dvan1966
Some times the kit isn't available but the parts are.
Maybe the priority block or valve is available and you could wing it after that.
tom
   / adding rear hydraulics #8
Try the Tractorsmart website. They are a pretty good resource for early model Kubota parts and kits.
BESTWAY AG VSK50 LOT NUMBER 103 (A53084)
BESTWAY AG VSK50...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
378538 (A51573)
378538 (A51573)
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT6DH646717 (A51572)
2013 Dodge Charger...
