Adding Power Steering to Ford 1700 4wd
   / Adding Power Steering to Ford 1700 4wd #1
BWBrown
Bronze Member
Northeast PA - an hour from everywhere
Ford 1700, IH 2500A
What I know about hydraulics I have learned by the seat of my pants, trial-n-error, and what I have read here.
Proposal: To add power steering to my Ford 1700. I just spent over 600.00 on parts to rebuild the standard steering. Loads on the FEL are not kind to it. This is the secong go-round replacing worm shaft and steering sector.
OEM power steering, new or used, are not available. I suggest the total replacement of the manual steering wheel, column, steering box/sector shaft, pitman arm and steering rod.
I have looked at this steering valve:
Surplus Center Item Detail
It is a load reaction valve, to be connected to a double acting hydraulic cylinder to replace the existing rod between the pitman arm and the ball end connection on the front left wheel.
Add a steering shaft and wheel, a couple hoses, plumb it from a power beyond port or a priority valve.
Except for choosing the exact sizes to fit and fabbing mounting brackets, it looks easy. What am I missing?
Let the education begin. Thanks in advance.
Bob
   / Adding Power Steering to Ford 1700 4wd #2
   / Adding Power Steering to Ford 1700 4wd #3
Also.. you may want to look at jackson power steering. he refits lots of older fords.. Might have some parts in stock and you can do some custom fabwork with them..
Soundguy
   / Adding Power Steering to Ford 1700 4wd #4
Are there any used lawnmower shops around there that might have some parts machines for commercial mowers? I think that the one I have out back might make a good donor for a small tractor, as the mower weighs over 2,000 pounds itself. Seems like there ought to be a way to purchase a used system and modify it to fit, rather than spending that much money trying to match up parts and hope they will work together. If you can find a retrofit that somebody made for another tractor, that would probably be the easiest way, like Jimmer and Soundguy mentioned.
David from jax
Actually, Jimmer, it was your project that got me thinking in this direction again. Thanks, guys, for the leads. This kind of exchange of ideas is what makes this hobby (obscession ?) so much fun.
I would consider purchasing some pulled parts from "retired" equipment if they were to be made available.
I'll be getting into this a bit more agressively after the holidays. In the meantime, I'll welcome any more ideas offered.
Bob
   / Adding Power Steering to Ford 1700 4wd #6
Glad my project helped spread the disease, I mean, idea. :D
Rob,
THANKS for the link - I'm on it! Looks like my project is now officialy back on the front burner.
Bob
   / Adding Power Steering to Ford 1700 4wd #9
That is essentially the same unit I just bought (mine is a 50 though, slightly bigger output).
All you need now, is a double-acting cylinder. You should be able to pick one of those up cheap on ebay.
   / Adding Power Steering to Ford 1700 4wd #10
2015 John Deere 410E (A50322)
2015 John Deere...
Pallet Fees (A50775)
KJ 20'x30' Metal Garage (A50121)
KJ 20'x30' Metal...
Satoh Beaver Tractor (RUNS) (A50774)
Satoh Beaver...
2017 Nissan Murano AWD SUV (A50324)
2017 Nissan Murano...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
