Adding power steering to a JD 950 with FEL
   / Adding power steering to a JD 950 with FEL #1
68mgc
MARTINS CREEK, PA
Mahindra, JD
Hello all, I bought a 1978 JD 950 with a great bend loader and I'm wondering about adding power steering. I'm a hydraulics novice so I'll try to explain what I'm thinking. The loader has an Aico controller with a capped power beyond valve. Can I use the PB outlet to a Parker hydraulic control valve then plumb from there to a Hoye DIY power steering cylinder assembly and then to the transaxle? I'm thinking I can adjust the control valve to get the steering I want without losing too much loader power. I want to try to avoid cutting into any hard lines. Like I said I'm no hydraulics expert so I could be all wrong. Any help would be appreciated. Thanks in advance.
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
23169 (A50324)
23169 (A50324)
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
2021 John Deere 331G Track Loader (A53342)
2021 John Deere...
