adding power steering to a Ford 1700
   / adding power steering to a Ford 1700 #1
wilsonbus
Central Mass
Ford 1700
Has anyone done this, and how hard is it to do? I have a broken steering box.
Fred
   / adding power steering to a Ford 1700 #2
I was going to mention that Char-Lynn might have a hydraulic assist motor that would fit between the end of the shaft and the steering wheel, but the broken steering box probably rules out that option. Maybe if you replaced/repaired the box first, then went the char-lynn route? Downside is that it raises the steering wheel up a few inches.
Although I don't see an entire kit listed for your 1700, maybe these folks might be able to help:
Power Steering Kits
Thank you for the info, I will check with them.
Fred
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A52748)
2021 NEW HOLLAND...
1265 (A50490)
1265 (A50490)
ASSET DESCRIPTIONS & CONDITION (A52577)
ASSET DESCRIPTIONS...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A52577)
2012 INTERNATIONAL...
2013 MACK GU713 (INOPERABLE) (A52472)
2013 MACK GU713...
