Adding Power Service
   / Adding Power Service #1
BillyP
Veteran Member
Eagletown, OK
JD 4610 ehydro MFWD
I recently acquired a 300 gallon diesel tank. I had it filled before I thought about adding the PS. Would it be ok just to add it now?
   / Adding Power Service #2
I always try to put it in before the diesel. I am guessing that you generator has a return line? If it does it will mix the PS for you. Just run it for a while. That is what I had to do the last time. The truck delivered the diesel when I was not expecting it. /forums/images/graemlins/crazy.gif
   / Adding Power Service #3
</font><font color="blue" class="small">( Would it be ok just to add it now? )</font>
Yes.
   / Adding Power Service #4
You'll be fine. I've never added it before. We always add it after they've filled the tanks.
OK, will do. Thanks guys.
Oh, Jerry. You're right, it does have the return line.
Thanks again.
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2000 FORD E350 CUTAWAY BOX TRUCK (A54313)
2000 FORD E350...
