Adding MMM to 4310???
   / Adding MMM to 4310??? #1
Twanger
Bronze Member
KCMO
4310 4wd ehydro 420 loader asof 4/2/02
I have the mid pto. I do not have the 3rd svc hyd. I do have the loader. Can I power the deck up and down with the bucket circuit then when I need the bucket use the pins to keep the deck in the up position without the hyds???
   / Adding MMM to 4310??? #2
Twanger,
It's been done, I've used the curl function so the loader boom
is still functional. You can lock up the deck like you say, or I think you might be able to adjust your cut height nob all the way to hold it up a bit also..
Duetz Power Unit (A50120)
Duetz Power Unit...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 TRITON TRAILER ALLMAND MAXI LITE 45 GENERATOR (A52472)
2019 TRITON...
2001 Dodge Ram Wagon 3500 Passenger Van (A51692)
2001 Dodge Ram...
