adding massey ferguson hydraulics
   / adding massey ferguson hydraulics #1
swill
I want to add auxiliary hydraulics to my MF 1433v. My local MF dealer went out of business, so the nearest dealer is now in another state. (Obviously I should have gotten them when I bought the tractor, but i didn't, so...)
Does anyone know how complex a job it would be for me to purchase the auxiliary hydraulics kit and add it myself? I have reasonably good mechanical skills, but have never worked on hydraulics.
Also, what are the practical advantages of single spool vs. double spool systems?
   / adding massey ferguson hydraulics #2
I installed dual remotes on my 1533. It's pretty easy but also pretty involved. On mine, once you remove the right rear wheel, inner fender shield, and seat, all of the new pieces bolt right in. It took me about 2 hours or so altogether. I don't know how different the 1433 is from the 1533, so your results may vary!
   / adding massey ferguson hydraulics #3
Dan, I'm wanting to add the same thing, by chance what did the kit cost.
pwdrhnd
   / adding massey ferguson hydraulics #4
Dont know if you will want to do this or not, but if you have a loader on your tractor you can do this. On my 1533 I added a set of remotes on the back by getting the bracket and a remote kit at the tractor dealer ( any tractor dealer should have this or tractor farm supply ) and then got 2 hyd hoses made the proper length at the parts store and got 2 quick couplers ( same as the loader hoses ) and ran them up to the joystick valve and when I want to use the set of remotes on the back I just disconnect the tilt hoses on the loader and plug in my new hoses for the back and use the factory joystick to control my new set of remotes. Probably cost me 60 bucks. Not facory but it works well. I pull a Kuhn hayrake with mine and it requires Hyd's.
I was just quoted $1700 for the 2 spool kit by a dealer a hundred miles away. Found same kit online for about $1530. either way seems kinda pricey.
(where do you ski powderhound?)
   / adding massey ferguson hydraulics #6
swill,
Do you have a loader on your 1433? If you do it is a lot easier and less expense to add remotes.
Unfortunately I don't have a loader. I think the loader comes with its' own hydraulics, but I don't know how they tie in. Do you know if they connect to the same place as the auxiliary hydraulics? (If I plan to get a loader some day, would I be ending up with an "extra" set of hydraulics if I put the auxiliaries in now?) Like I said, I'm not too familiar with hydraulics.
Jerry: To clarify the extent of my ignorance and thus the degree of my confusion, I don't know what a "full set" of hydraulics on my tractor would include.
If, for instance, I had purchased my tractor with a loader and a backhoe and wanted to run an hydaulic top link and hydraulic side link for 3 point implements, how would my hydaulic system be '"wired"? Would the backhoe have a separate system from the auxiliary hydraulics? Would it be separate from the loader? Or would they all be tied in to a common valve kit to supply the hydraulic pressure?
Seems like if they are all separate systems, then I don't loose much by doing the auxiliaries first, but if they would all have common parts, I might be better off buying one of the other attachments first.
   / adding massey ferguson hydraulics #9
I got the kit from the dealer when I bought the tractor new this past August. It was $800 then. :cool:
Dan
Dan: Who is your dealer in CT, and do you know what the part number was for your kit? Was it a MF kit or some other after market kit. Price you paid was certainly a lot better than I am being told and maybe I should contact your dealer.
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
2016 Ford Explorer...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2001 MACK RD688S (A52472)
2001 MACK RD688S...
2014 Doosan DA30 (A52748)
2014 Doosan DA30...
