Loader Adding LA211 and Hydraulic Block / Lines to my BX 1830 for First Time - Suggestions?
   / Adding LA211 and Hydraulic Block / Lines to my BX 1830 for First Time - Suggestions? #1
Plow Paul
Madison, Va
Kubota BX1850
I picked up a nice used LA211 loader with valve locally via Craigslist and then got the complete hydraulic block/lines setup for my tractor from a member of this forum, which was a huge help and greatly appreciated. I got the BX 1830 new in 2005 without a loader or any loader valve or lines. I will be removing the blank cap and plug from the pump and adding the block with two lines and the swivel elbow with third tank line. I have read the instructions and gotten a couple of new O-rings for the block before putting it on.
So I figure I will thoroughly clean under the tractor and switch out the cap/plug with block, elbow and lines. I've worked with hydraulic equipment in the past, so I don't anticipate having any trouble hooking up the lines and clamps. I will hook up the two lines together where the lines terminate at the loader end per the manual.
The tractor had plenty of fluid when I checked.
At this point, I assume I would start up the tractor and check for leaks? If no leaks, then hook up the loader and try it out?
I assume the oil in the loader is clean filtered oil. It's time to change the hydraulic fluid in my tractor anyway, so I figure I will get it going, recheck the fluid level, run it a while then change the fluid/filters.
If there is anything else to check or be aware of, please leave feedback, it will be greatly appreciated!
Thanks in advance.
2015 John Deere 310SL (A47384)
2015 John Deere...
2015 CATERPILLAR 279D SKID STEER (A51242)
2015 CATERPILLAR...
Mayrath 10 x 31 Truck Auger (A50514)
Mayrath 10 x 31...
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
Land Honor Skid Steer 3 pt Hitch Adapter (A50515)
Land Honor Skid...
