Adding Hydraulics to a new tractor
   / Adding Hydraulics to a new tractor #1
RollTideRam
Veteran Member
Hartselle, Alabama
Kioti DK 4710 Cab
I am a few weeks out on buying a new 2520. I am new to tractor hydraulics. I don't understand all the hyraulic hookups that are needed on a tractor either. On the model I want, I am going with a loader and mmm. Have been told that you can't use both at the same time without modifying the hydro system. I know that I will not mow often with the loader on, but there might be times when I need the loader, and don't want to remove mower for a small job. Surely the dealer will know what to do, but just in case, I would like to know what I'm looking at. Also, would I be better off to get hyraulic connections on the rear of the tractor for future implements. I like what I have read about the hydraulic top link, but probably will not be able to get on right now. Thanks for any advice. JC
   / Adding Hydraulics to a new tractor #2
You can leave the mmm on but will not have all its functions ,when i use my mower i connect the independent lift ports to the curl ,roll ports of the system so i can still raise and lower the FEL mine as been a great machine so far only about 10 hrs on it good luck
2011 Chevrolet Suburban SUV (A51694)
2011 Chevrolet...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2016 Kubota RTV X900 (A50123)
2016 Kubota RTV...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
