Adding hydraulics & Remotes
   / Adding hydraulics & Remotes #1
bildo
Central Ohio
2005 Bobcat S250 Highflow/turbo....looking to get a tractor sometime soon too
Hello all, I am new to the big tractor game and are looking for a great quality tractor for my property. I am in love with the Kubota M59 but man are they expensive( i would love a 62 or 47 but don't have that kinda money) so I'm wondering how well does everyone think an older 59 would be and what the costs might be to add a hydraulic thumb and some remotes? or would it be smarter to buy a loaded machine for maybe $8-10,000 more? any and all thoughts appreciated.
Background
- 41 heavily treed acres...need to cut and clear for a drive, house, general vegetation control. plus i will have to create a culvert pipe project to span about 20 foot creek bed(probably double 48inch HDPE), im 38y/o
Thanks all...ps.the information on this site is awesome(long time reader first time poster)
:confused:
B
   / Adding hydraulics & Remotes #2
I think for what you want to do, the cost for what you get capability wise ain't great. Then once the drive, house, etc are done....what use do you have for the machine?
Without knowing more background, and what future uses you have after the initial hard work is done....you might consider a 2-machine plan. Either a used full sized backhoe...or a mini /midi excavator....and a 40-50hp compact tractor. Sell the big backhoe or excavator once the hard work is done, and take care if property maintenance with the tractor from there on out.
Renting the big equipment is another option if you don't feel comfortable buying used and trying to resell.
But spending a ton of money on a M59 or M62 if you cannot put it to work once the hard stuff is done, don't make much sense to me
Yes i have been thinking this as well, but i will be attempting to start a small farm(wood clearing so forth) with my family and with the densely packed woods and the strength and versatility of the machine have me thinking its a good choice. Would you have another recommendation of tractor type? I fear the weekness of a 3point hoe. I've been reading some of your posts about adding remotes and thats where this all kinda started with the less expensive machine. But i would like to be able to move a lot of lumber around and remove the stumps and so on.
   / Adding hydraulics & Remotes #4
LD1 nailed it as usual.
In 2009 I had a "need" I thought for an L35/L39 for my first tractor for use down in Mississippi. I "needed" to make ATV trails on several hundred acres we own. I was planning on building a house. It would have been great.
After a lot of reading here I came to the realization that unless you are stuck out in nowhere it's usually better to rent/hire for the "one off" chores.
What are your plans for the next 60 years?
You might be better off with a similar sized tractor w/o the backhoe but $5,000 in attachments.
Are you going to be maintaining a road? Grading? Snow removal?
What about your forest? Is that going to be a source of income or just let it grow?
I'd still love it if some kind person gave me a $50,000 M47, but I spent $12K on a used M4700 with similar capabilities, except for the backhoe. IMG_20151207_150524186_HDR.jpg
And with the leftover $$$ have bought a lot of attachments.
I'd still love it if some kind person gave me a $50,000 M47, but I spent $12K on a used M4700 with similar capabilities, except for the backhoe.View attachment 489599
I know exactly what your thinking. I have been in this debate with myself for atleast 1 and a half years. The plans are to maintain everything and if i can create a small source of income from the trees i will. I don't wanna kill myself with excessive work if i can help it. I like the strength of the machine, plus the ability to take the how off and still be able to use the tractor aspect. I don't know anymore. I am at a point of having to save money for the house and everything by doing most things myself. Just looking for all insight.
   / Adding hydraulics & Remotes #6
The 50-60k pricetag for a new...or gently used m59/62 is my concern.
If you can afford it, and thats what you want, by all means go for it.
But I see nice used industrial machines like case 580's, Deere 310's, etc with 3k-4k hours for half that or less. And they are way more capable/robust. And could likely put several hundred hours on it doing the major work, and sell it for the same as you paid.
Then look at some nice 40-60hp loader tractors and spend the difference on attachments.
   / Adding hydraulics & Remotes #7
A suggestion. I own 85 acres that was very heavily forested. Also plan on building a house there. We had timber cut and as a result they cut my roads since they themselves had to have access to the areas to cut. In essence you have someone else make your roads for you. then have someone come in and push up your stumps and clear your home site. Have the gravel company come in dumping your loads of gravel and then spread it out with your tractor. You go in and flag the route that you want the loggers to haul out the timber. The logger has basically paid you to build your road at that point.
   / Adding hydraulics & Remotes #8
That's a good outside-the-box thinking as long as there is enough harvestable timber:thumbsup:
   / Adding hydraulics & Remotes #9
Re: My Thoughts
I started building my house on 25 mostly wooded acres back in 1979 when I was 33. I was faced with many of the same tasks you are dealing with now. I also wrestled with the idea of buying a larger tractor to do most of the work myself. I quickly discovered that no single machine can do it all. In the end, I put the money in the house, rented machinery and contracted out the larger tasks.The seat time I didn't put in on a tractor, I was able to use to make money and build sweat equity in the house. I did buy a small Kubota B7100HST with FEL and BH to do some of the smaller jobs however. It still amazes me what I did with that little machine.
Now, 37 years and four Kubota's, later, i've worked my way up to an MX5800HST. Along the way, I modified the machines, added equipment, remotes etc. as needed. I found the bigger machine has its benefits but also some negatives. I maintain 20+ acres of rough wooded terrain and I find the larger tractor to be more difficult to maneuver in cramped areas. In my case, a cab is out of the question. The roads I originally cut could easily be navigated by the B and small L series tractors but required enlarging to accommodate the MX. Now it seems I have more acreage devoted to roads than trees.
My advice is to start small and work your way up as the need arises. Buying, selling, maintaining and operating larger, older machinery takes time and money that IMO is best put into the house.
Re: My Thoughts
yes i've been thinking long and hard about everything everyone is mentioning. plus everything else in my head. I wish i just won the lottery and solved all of my problems. :confused:
BESTWAY AG LOT NUMBER 53 (A53084)
BESTWAY AG LOT...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2,500lb Traveller ATV Winch (A51573)
2,500lb Traveller...
