Adding Hydraulic Remotes
/ Adding Hydraulic Remotes #1
VA Orange
L4310 HST
Good Morning Everyone........I have an L4310HST and was wanting to install hydraulic remotes. Can anyone give me an educated guess on how much a dealer would charge to install these? Thanks.
/ Adding Hydraulic Remotes #2
Welcome to TBN my fellow Virginian! Where you located?
I paid my dealer $149 for the optional 2nd rear remote to be added. I think the Bobcat dealer was charging $179 or 169 each.
It was a smart decision in my book.
Happy Tractoring! :tractor:
Be well,
David
/ Adding Hydraulic Remotes #3
Normally the first remote is the most expensive. The factory kit includes an adapter to tap into the hydraulic system. Then additional remotes stack onto the first and are less expensive.
If you already have a loader they could be added for a bit less with non factory parts.
I added four remotes to my L3800 and I spent about $1200 on parts and did all of the installation myself.
I used all quality parts and that figure included everything down to the last tie wrap.
I assume by your user name that you are in VA.
If you're close enough to me I could give you a hand if you needed.
What did you want to operate with the remotes?
Top & Tilt?
Front grapple?
Check out my remote install
http://www.tractorbynet.com/forums/...g/208593-top-tilt-rear-remotes-installed.html
/ Adding Hydraulic Remotes #4
You did ask how much the dealer would want to install, I'd guess parts and labor about a $1000-$1500.
/ Adding Hydraulic Remotes #5
The installation of the rear remotes is an easy job. I just installed one factory rear remote on my L3240-HST. The kit was $650 from the dealer. Installation took about 90 minutes.
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
4" Makita Disc Grinder (A62613)
4" Makita Disc...
2023 New Holland Procart 1428 Rake (A63688)
2023 New Holland...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
Frontier Forks (A64126)
Frontier Forks...
2008 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2008 CM TRAILER...
