Adding hydraulic function to Kubota L245DT
   / Adding hydraulic function to Kubota L245DT #1
bigsnowdog
Deere 5500 Kubota L245DT, Ferris 3100
I have a Kubota L245DT I bought new with a Kubota quick-detach loader. When the loader is off, you are to connect the two rear hoses together.
I want to add necessary parts and function so I can run a dump wagon at the rear. What parts are necessary to implement this possibility?
Thank you.
   / Adding hydraulic function to Kubota L245DT #2
Does your dump wagon have a valve?
When using QD in hyd circuits, it is good practice to always protect the pump by adding an external relief valve across the pump.
If your loader has PB now, then some options are below. When you remove your loader, Call the pressure line QD-P1, and the other line QD-P2. These two QD's are plugged together for 3pt operation.
You can add a one two or three spool remote valve with PB, at the back with QD's installed on the input and PB output port on the back. The tank port can go directly to tank.
Hyd flow path would be something like this. Pump flow through QD-P1 to the remote valve, remote PB out to the 3pt in QD-P2 and tank/return to tank.
Add QD's to the work ports for the wagon.
Is the wagon cyl a DA cyl or a SA cyl?
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2023 FG INDUSTRY STE 35SR MINI EXCAVATOR (A51222)
2023 FG INDUSTRY...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
Adams 5 ton Fertilizer Buggy / Wagon (A51039)
Adams 5 ton...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
