Adding Hydraulic Fluid
   / Adding Hydraulic Fluid #1
Flyhot
Pelzer, SC
LS 4140
I am having a severe brain cramp! Where in the world is the hydraulic dip stick and where do you add the fluid to a 4140?
   / Adding Hydraulic Fluid #2
Look just behind the PTO shield. Upper right area just by it. Check & fill from same spot (use funnel of course to fill :) ). You might have a separate fill - if so, those are generally opposite side of the dipstick.
2005 Sterling Semi (A50514)
2005 Sterling Semi...
2013 Derek Digger (A50323)
2013 Derek Digger...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
2017 CATERPILLAR 259D SKID STEER (A51242)
2017 CATERPILLAR...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
