Adding Hyd to a Ford 3600
   / Adding Hyd to a Ford 3600 #1
kioti79
Manchester Ia
John Deere 455
Hello I've mostly just been on here to read and learn but I haven't been able to figure out from just reading what I need to do to get my set up put together. I've read several posts on here and have worked on hydraulics before but am new to Ford tractors and just purchased a Ford 3600 and want to add a light duty loader that I have to this tractor. But I am a little confused on which Adapter block I should get there is the HV4902 and HV5902. My loader was on a narrow front Massey tractor and has 2 quick couplers that plugged into the hyd ports and the hoses run up to the valve block. I would like to set it up the same way on the Ford. So which adapter block will allow me to do this and still be able to use the 3point for the blade already on the tractor. Also how would I determine if the existing levers/valves on the loader are open or closed center and which will i need to make this all work.
I know the loader will be slow and a auxiliary pump would be better but I won't be doing a lot of work with it its more for use of moving a little dirt here and there, or pushing snow. Eventually when more funds allow I may add a crankshaft driven pump.
Glad I have found this site have found alot of good info on here and thanks in advance.
Anyone have some input on how to set this up?
Thank you Harry in Ky
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
Unused Delta Crash...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
