Adding FEL to older tractor (Hydraulic specific question)
   / Adding FEL to older tractor (Hydraulic specific question) #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I have a 1991 Massey Ferguson 283. I was considering adding a FEL. A friend told me to turn on the PTO, then depress the clutch all the way to see if the PTO shaft stopped spinning. Sure enough it did. He then proceded to tell me that the FEL would not function as most modern ones do. Can anyone here clarify this. What can I expect if I do in fact add a FEL to this tractor. thanks
   / Adding FEL to older tractor (Hydraulic specific question) #2
If you have the clutch pushed in, will the 3 point lift up? If no, you wont be able to lift the loader while the clutch is in, but it should work otherwise.
Aaron Z
   / Adding FEL to older tractor (Hydraulic specific question) #3
Not much info on that tractor here
TractorData.com Massey Ferguson 283 tractor information
But it does mention a 2-stage clutch, which is true of a LOT of tractors - push the clutch in partway, tractor stops driving - rest of the way, PTO stops. That way you can do things like lift/clear a tiller without the tractor moving, etc.
IF you can raise the 3point with the clutch fully depressed, then your hydraulics are coming from a motor-driven pump and you may be able to find a place to "steal" a hydraulic feed for a FEL.
The hydraulics are open center on that tractor (typical) so all you'd need (besides some head scratching) would be a point prior to the 3-point control valve to cut into the pressure feed from the pump, a return to the 3-point valve from the Power Beyond outlet of the new valve(s), and a tee into the tank return circuit for the new valve(s) outlet.
Oh, and a good place to hang valves where they'd be reasonably ergonomic.
I'd recommend 3 or more valve setup, one with float for loader height, one center detented for bucket curl, and a spare for a grapple or other front add-on. You can also find a couple of ways to get a joystick setup to put lift and curl on the same lever. Very intuitive, my backhoe has that and it's great.
I'm just getting started on a 4-valve rear remote setup on an old allis-chalmers, and since yours is also made in either England or Brazil you may find existing high pressure hard tubing to be metric. Mine is 12mm.
Fortunately, Discount Hydraulics DiscountHydraulicHose.com has you covered. They have metric compression - to - JIC, ORB, etc - adapters.
Gotta run for now, if I've got you curious ask away - I'm glad to share whatever I've found that might save you some headaches... Steve
2012 Chevrolet Cruze Sedan (A53424)
2012 Chevrolet...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
Case Titan 3530 (A55218)
Case Titan 3530...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
kids dirt bike (A53424)
kids dirt bike...
1264 (A50490)
1264 (A50490)
