Adding controls to run 3 pt hitch attacment from backhoe rear
   / Adding controls to run 3 pt hitch attacment from backhoe rear #1
Solidoak
Washington
Case 580
So I would like to add a 3 pt hitch to a case backhoe. The backhoe is originally removable (with controls) and there are two hoses that feed the hydraulics which use large quick-connects. There is about 6 cylinders that run the hoe (3 that can run constantly for your basic dig functions). I would like to install a common 3 pt hitch that will have 2 cylinders (2 spool valve)... What would be the correct way to plumb into this system? What type of valves and reduction would need to be done to make this function well?
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
John Deere 12' Grain Drill (A50515)
John Deere 12'...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2016 CATERPILLAR 325FL EXCAVATOR (A51242)
2016 CATERPILLAR...
Lightweight 5' Pipe Gate (A50515)
Lightweight 5'...
2021 CATERPILLAR 289D3 SKID STEER (A51242)
2021 CATERPILLAR...
